JeyDe
Pi 3B as WiFi server, NodeMCU as client
Thu Jun 14, 2018 10:46 am
Hello everyone,
im new to the Pi scene and I have a project i currently work on.
I want to messure 2 temperatures and send them to Pi 3B via WiFi. My sensoring Programm on a NodeMCU works fine so i just need to set up the connection and find a way to send the data over to the Pi. My research wasnt as fruitful as I hoped it to be as most projects I found are several years old and have to use a WiFi stick to work properly.
Project:
I measure 2 temps with sensors connected to the NodeMCU. The MCU is programmed with ArduinoIDE and I have the ESP8266WiFi.h library included.
I want to use a Raspberry Pi 3B as server and as a tool to directly show the data in realtime with display.
If you have any ideas or a link where i can find a working example that would help a lot!
Thanks and have a nice day!
JeyDe
Ps: no native english speaker so I apologise for every mistake I made ;)
JeyDe
Re: Pi 3B as WiFi server, NodeMCU as client
Thu Jun 14, 2018 1:28 pm
I forgot to say one thing: the system is not connected to any LAN and will not be connected to the internet.
mattmiller
Thu Jun 14, 2018 2:03 pm
Typical steps would be
Setup Pi as a WiFi access point so that the nodeMCUs can connect to it
Run an MQTT broker on the Pi
Send data as MQTT messages from nodeMCUs to Pi
Then you need method to display the data
One method (out of many) is to run Node-RED on the Pi to read in the MQTT data and use dashboards nodes to display the data on a webpage
quite a few steps needed - great summer holidays project :)
JeyDe
Mon Jun 18, 2018 8:20 am
Thanks for the answer! That MQTT idea seems to be a good one! I'll Keep you updated :)
V8Diego
Thu Aug 30, 2018 11:16 pm
Hello!
I have my raspberry pi configured as an access point.
I have connected a nodeMCU to the broker without problem, however other two nodeMCU that I have connect without problems to the network generated by the raspberry pi, but they are not able to connect to the broker ever.
I have tried to connect one at a time, but there is only one that manages to connect (always the same) and the others do not.
Do you know what could be happening?
mattmiller
Fri Aug 31, 2018 4:37 pm
try giving them different client ids and see if that solves the problem
