rogermiranda1000
Two applications using the camera
Thu Jun 14, 2018 10:07 am
Is there any way to have two applications use the camera?
Yesterday I installed an application that retransmits the camera on web on-line, and now I can't use mu other python files that make photos.
Here I leave the tutorial and the code of one of my files:
https://elinux.org/RPi-Cam-Web-Interfac ... e_Shooting
#!/usr/bin/python
import time
import picamera
with picamera.PiCamera() as picx:
    picx.start_preview()
    time.sleep(5)
    picx.capture('mifoto.jpg')
    picx.stop_preview()
    picx.close()
Re: Two applications using the camera
Thu Jun 14, 2018 10:41 am
Not possible.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
mahjongg
Thu Jun 14, 2018 11:23 am
No, not at the same time.
But I think that if one application stops using the camera, and relinquishes its use of the camera, that then another application can use the camera afterwards.
Its not as if somehow the camera knows it should only work with the first application that uses it.
I don't know how to relinquish the use of the camera (interface) though, I don't own a raspberry PI cam.
rogermiranda1000
Thu Jun 14, 2018 11:36 am
Anyone can help me doing this? (Finding the code that makes the website camera works and modify it, so when a photo needs to be made stop using the camera, and then re-activate it)
Or you can recommend me a better option for the website.
Thu Jun 14, 2018 11:46 am
The best way would be to build a "camera server". It grabs the camera and takes a picture when requested.
Your client application would send a request to the server, the server would respond with the filename just captured.
That should be fairly easy to design and build. I'd use MQTT as the command and control process. You could write your own protocol and run a TCP/IP listener of your own.
rogermiranda1000
Thu Jun 14, 2018 12:14 pm
OK, I will try it.
rogermiranda1000
Mon Jun 18, 2018 8:19 pm
I created my own code.
It isn't as good as the other, but it works.
Now I hope I don't have any more problems.
Thanks for your help!
Return to “Camera board”
