neocubo
Doubt with raspberry pi battery
Wed Jun 13, 2018 10:46 pm
Hi, I have this battery. Would there be any problem if I used it to connect to raspberry pi?
davidcoton
Re: Dude with Battery for raspberry pi 3
Wed Jun 13, 2018 10:59 pm
It might work if you have nothing much connected to the USB and drawing power. 1.5A is below the 2A minimum recommended for a Pi3B (Pi PSU is 2.5A, Pi3B+ has that as its minimum recommended supply).
You will need good (thick, short) wires from battery to Pi. Off charge, it will last about an hour. There is no indication about whether it can supply power while charging -- the input spec suggests not.
"Thanks for saving my life." See https://www.raspberrypi.org/forums/viewtopic.php?p=1327656#p1327656
“Raspberry Pi is a trademark of the Raspberry Pi Foundation”
Return to “Beginners”
