cjan
red light blink
Wed Jun 13, 2018 10:18 pm
system running fine, but red light blink randomly, what does it mean or Pi dying?
davidcoton
Re: red light blink
Wed Jun 13, 2018 10:48 pm
It means the 5V power supply is going below 4.65V. Either the PSU is inadequate, or the cable from PSU to Pi is too long or thin, or something else is loosing volts along the way.
Which model Pi?
What is connected to it (anything on HDMI, USB, or GPIO)?
What is the PSU spec (V and A)?
"Thanks for saving my life." See https://www.raspberrypi.org/forums/viewtopic.php?p=1327656#p1327656
“Raspberry Pi is a trademark of the Raspberry Pi Foundation”
cjan
Re: red light blink
Wed Jun 13, 2018 11:24 pm
Which model Pi?
thanks, P2b 5V 1A connect to HDMI, but its all used for 4 years until now.
had another 5.2V 1.23A, can i use?
drgeoff
Re: red light blink
Wed Jun 13, 2018 11:40 pm
Which model Pi?
The 5.2 volt supply will probably be OK. Not all PSUs live up to the specs implied by their labels. Furthermore, switched mode PSUs (the modern lightweight ones that run comparatively cool compared to the old heavy ones) do have a propensity to slowly fade away.
