sgrayban
How to get a secure console login prompt on PI 3
Wed Jun 13, 2018 8:12 pm
Actually I did find how to do this....
edit /etc/systemd/system/autologin@.service
find [Service]
edit
ExecStart=-/sbin/agetty --autologin pi --noclear %I $TERM
change to
ExecStart=-/sbin/agetty %I $TERM
Reboot
Now your PI 3 will boot and have a secure console login.
NOTE: The screen doesn't clear like a normal debian login and I can't figure out how to do that without editing rc.local and adding a clear command so it's just cosmetic by product for now.
n67
Re: console exit does not logout to login prompt
Wed Jun 13, 2018 8:19 pm
Need some more details.
Which OS?
How did you install it? How did you configure it?
Is it connected to network?
When you say "console login", do you mean exactly a "virtual console" login?
Maybe post a screen shot, just to make sure we're all talking about the same thing.
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
sgrayban
Re: How to get a secure console login prompt on PI 3
Wed Jun 13, 2018 8:49 pm
I figured it out... PI enables auto login no matter what I change in the raspi-config
I edited this post to reflect the right way to do this.
mfa298
Thu Jun 14, 2018 10:31 am
find [Service]
edit
change to
Reboot
You shouldn't have to go editing systemd service files to change that functionality. If you look at what raspi-config does for console autologin it changes the path for /etc/systemd/system/getty.target.wants/getty@tty1.service If that's not working. To disable autologin it should point to /lib/systemd/system/getty@.service which is effectively the same as your change.
The issue with your method is that if the package owning the file you altered gets updated (which happens a few times a year) your change could get put back to the default.
Return to “Advanced users”
