Dear All
I run Pi 3 as a web server, when I install a php script in folder /var/www/html/ and run, I got this error :
Not Found
The requested URL /authenticate/login was not found on this server.
I see error.log as below:
"[Wed Jun 13 15:10:37.595280 2018] [:error] [pid 1429] [client 192.168.1.18:65103] PHP Warning: file_put_contents(check_install.txt): failed to o$
$n/config/verify.txt): failed to open stream: Permission denied in /var/www/html/installer/setup.php on line 185, referer: http://192.168.1.14/"
I can only access the index.php in /var/www/html/ and the others can not access, Pls help me let me know how I can fix this problem. Tks
