fred44nl
no reboot after "sudo touch /forcefsck"
Wed Jun 13, 2018 8:24 am
so, I did "sudo rpi-update", which gave me kernel 4.14.48-v7+
next, I did "sudo reboot now", which resulted in a proper reboot.
after that, I did "sudo touch /forcefsck", rebooted and my RPi did not come back.
waited like 15 mins. there was no usb-HD activity.
so I pulled the power-supply.
re-applied power and the RPi booted properly.
this problem also showed itself with kernel 4.14.34
pls. note: I boot from the SD-card and run from an usb-HD.
the last entries in /var/log/syslog, before I pulled the power-supply, are:
Jun 12 11:49:34 raspberrypi ntpd[577]: Soliciting pool server 87.233.197.123
Jun 12 11:49:34 raspberrypi ntpd[577]: Soliciting pool server 83.162.251.163
Jun 12 11:49:34 raspberrypi ntpd[577]: Soliciting pool server 94.228.220.14
Jun 12 11:49:34 raspberrypi ntpd[577]: Soliciting pool server 149.210.199.182
Jun 12 11:49:35 raspberrypi ntpd[577]: Soliciting pool server 83.247.2.80
Jun 12 11:49:35 raspberrypi ntpd[577]: Soliciting pool server 217.23.3.234
Jun 12 11:49:35 raspberrypi ntpd[577]: Soliciting pool server 5.39.184.5
Jun 12 11:49:35 raspberrypi dhcpcd[504]: eth0: no IPv6 Routers available
Jun 12 11:49:36 raspberrypi ntpd[577]: Soliciting pool server 45.32.4.67
Jun 12 11:49:36 raspberrypi ntpd[577]: Soliciting pool server 83.98.155.30
Jun 12 11:49:37 raspberrypi ntpd[577]: Soliciting pool server 85.255.214.66
Jun 12 11:49:37 raspberrypi ntpd[577]: Soliciting pool server 2001:bc8:2bf2;100::
note: the semi-colon in the last line was a colon, but that displays something strange.
where does it go wrong ??
headless RPi 3B running from usbhdd.
epoch1970
Re: no reboot after "sudo touch /forcefsck"
Wed Jun 13, 2018 9:56 am
I would advise against using "rpi-update".
That pulls development firmware and kernels:
- you have no guarantee either will work,
- only a few users will ever run the same system as you.
If you want a good running system and community support use only released versions (from apt-get upgrade)
fred44nl
Wed Jun 13, 2018 10:20 am
yes, I know, but this was advised in this topic:
viewtopic.php?f=28&t=215625
epoch1970
Wed Jun 13, 2018 10:56 am
Why change thread then?
fred44nl
Thu Jun 14, 2018 9:24 am
well, because my problem is not the same as what the original poster had.
epoch1970
Thu Jun 14, 2018 9:07 pm
The "problem" can't be solved by anybody not running that version.
