prioryjim
Spring watch DIY camera
Wed Jun 13, 2018 7:23 am
You probably know of this project using a Raspberry PI.
At
https://mynaturewatch.net/terms-and-conditions
I want to build one but I think it involves a PI with in built wifi.
I have a PI with camera port but no wifi I use a usb dongle.
Their image does not seem to work.
Does anyone know of any forum for this project as I have a number of questions.
Jim
B.Goode
Re: Spring watch DIY camera
Wed Jun 13, 2018 8:09 am
https://mynaturewatch.net/contact/
The My Naturewatch cameras are prototypes and are still being developed and tested in different scenarios. Your input will help us understand how people might use the camera kits and help us improve our designs.
If you have written the image to the microSD card correctly, maybe the image is fine but does not support your WiFi dongle and thus does not active itself as an Access Point?
Would it be possible to connect a display and keyboard to modify the configuration?
prioryjim
Wed Jun 13, 2018 9:20 am
I have keyboard and mouse attached and it boots to command line
I edit /etc/network/interfaces
And added my IP and wifi details.
I can now connect over the net using putty
And also get a web page with Start Recording , Sensitivity , View Photos
Currently I have no camera, they are out of stock !
But will get one eventually.
Where is best place to ask questions ??
Thanks,
Jim
B.Goode
Wed Jun 13, 2018 9:45 am
If it is specifically about the Mynaturewatch project, and the Operating System they have provided, I still suggest their own Contact page.
If it is a general question about your unspecified model of RPi you should probably use these forums.
You have not chosen to use the option in the forum software to indicate your location, but I note that in the UK the Raspberry Pi Foundation camera module seems to be in stock at all the usual suppliers. See https://www.raspberrypi.org/products/camera-module-v2/
DirkS
Wed Jun 13, 2018 10:00 am
FYI: Pimoroni's kit for this project actually contains a v1 clone camera board: https://shop.pimoroni.com/products/my-n ... ard-camera
prioryjim
Wed Jun 13, 2018 10:20 am
Thanks for the info
I still see them out of stock for the standard one at
https://shop.pimoroni.com/products/rasp ... 7751082058
Regards
Jim
P.S. Preston UK , I will update profile
B.Goode
Wed Jun 13, 2018 10:32 am
CPC-Farnell claim to have several hundred in stock. http://cpc.farnell.com/raspberry-pi/rpi ... dp/SC14028
If you have transport you could use Click and Collect to get one 'over the counter' from their Preston outlet:
CPC
Component House, Fulwood, Preston
PR2 9PP
prioryjim
Wed Jun 13, 2018 10:56 am
Hmm £25.91
https://shop.pimoroni.com/products/rasp ... era-module
Seems to say £14.00
Are they the same I wonder ?
Jim
DirkS
Wed Jun 13, 2018 1:48 pm
Hmm £25.91
Seems to say £14.00
No.
CPC is official RPF v2 camera (8MPixel)
Pimoroni is a v1 clone (same camera, but not the same board, etc.
B.Goode
Wed Jun 13, 2018 2:45 pm
Hmm £25.91
Seems to say £14.00
Jim
As @DirkS has pointed out, No, not the same.
The Pimoroni listing is Not for an official Raspberry Pi Foundation camera module, which is what I checked the availablity for. It has lower resolution, and is only compatible with RPizero boards with a camera connector.
If the RPi board you are trying to use for this project is a standard model with a 'full size' (credit card size) circuit board you may find the Pimoroni camera cable does not fit.
prioryjim
Thu Jun 14, 2018 10:47 am
OK I got my V2.1 camera and adapter cable for the PI zero from Pimoroni, VERY quick delivery!
There was a white disk with a hole in the centre in the box.
What's that for ??
DirkS
Thu Jun 14, 2018 10:54 am
B.Goode
Thu Jun 14, 2018 11:03 am
B.Goode wrote:
Thu Jun 14, 2018 10:50 am
https://shop.pimoroni.com/pages/contact-us
or https://forums.pimoroni.com/
Listed on the Contact Page, along with their Discord 'chat room' which can sometimes be more responsive.
DirkS
Thu Jun 14, 2018 1:14 pm
Ah... of course I did not check that first.
prioryjim
Thu Jun 14, 2018 1:55 pm
After much surfing the little white disk was
https://www.adafruit.com/product/3518
prioryjim
Tue Jun 19, 2018 12:13 pm
Also I think they have a forum now
https://mynaturewatch.net/forum
Return to “Camera board”
