RoddyJoff
How to install nZEDb on RPI
Sun Jun 10, 2018 2:16 pm
I have been trying to install nZEDb onto my RPI 2B+ for the last week or so and am driving myself mad!
I have tried Wheezy, Jessie and finally the latest Stretch.
First of all I used this:
https://linuxconfig.org/how-to-install- ... etch-linux
to install LAMP with no errors being reported
Everything works including the default Apache index.html file when I connect from my Mac at 192.168.0.20
Next I installed nZEDb using the following command:
sudo git clone https://github.com/nZEDb/nZEDb.git /var/www/nZEDb
and this is where it starts to wrong.
I discovered that the default web directory on Stretch differs to that of Wheezy. The original nZEDb installation expects /var/www but it now is /var/www/html on Stretch.
I therefore attempted to ‘fix’ this by changing sites-available and DocumentRoot and other things I cannot remember, getting myself into an endless loop.
If I install a simple index.html file in /var/www/nZEDb before making any changes then 192.168.0.20 works insofar that I get the message in the index.html file so why doesn’t 192.168.0.20/install work, having removed the index.html file?
I am at a loss to say the least. I am about to re-install Apache to set everything to a base/normal state but after that don’t know where to go.
Should Iinstall nZEDb in a different directory??
ie: in which directory should I execute this command:
/var/www or var/www/html or /var/www/nZEDb
Many thanks.
The best things in life are free.
scruss
Re: How to install nZEDb on RPI
Sun Jun 10, 2018 4:51 pm
A Raspberry Pi doesn't meet the nZEDb Hardware Requirements:
4GB RAM, 2 cores(threads) and 20GB disk space minimum.
If it runs at all, it will be dismally slow
RoddyJoff
Sun Jun 10, 2018 5:59 pm
Hi Scruss,
Thanks for the reply.
I realise the RPI2B+ is woefully inadequate and I do not intend to use it with any great expectations.
My reason for the post was to try and understand how the installation package works. I cannot fathom how to install the programme snd run the install option. I am at a loss and am hoping someone can explain how to launch the ‘install’ programme on Stretch.
Cheers.
Sun Jun 10, 2018 6:46 pm
Hi Scruss,
Cheers.
Did you check the Hardware Requirements ?
https://github.com/nZEDb/nZEDb/blob/0.x/README.md
adieu
My other Computer is an Asus CS10 ChromeBit
RoddyJoff
Sun Jun 10, 2018 8:41 pm
I know the Pi is not adequate.
My question is how to understand how to install the software.
Sun Jun 10, 2018 8:48 pm
Read the instructions at: https://github.com/nZEDb/nZEDb/blob/0.x/INSTALL.txt
Note:Having anything remotely humorous in your signature is completely banned on this forum.
RoddyJoff
Mon Jun 11, 2018 9:25 am
Hi Dougie,
Thanks for your reply.
I am afraid I have over-complicated my question so please ignore any reference to ‘nZEDb’
My dilemma is:
I have a piece of software that was intended to be run on Wheezy using a standard LAMP server. The installation instructions are extremely easy according to the instructions at:
sudo git clone https://github.com/nZEDb ... /www/nZEDb
Having ensured Apache, MySQL, php &tc are ruinning as expected (and they are) then the final installation instruction is:
nZEDb Initial Setup Configuration
Point your browser to the box http://ip.address/install to start the Installation setup
which should result in a page as shown below and then the user is expected to follow the instructions from that page onwards.
However, and here is where I ask you to ignore references to nZEDb, Wheezy expects the Apache DirectoryRoot to be at /var/www but Stretch has moved it to /var/www/html
I installed the software at /var/www/html but when accessing the address http://ip.address/instal nothing happens. Similarly if I install at /var/www then again nothing. I tried the latter and changed all references to DirectoryRoot I could find without success.
I appreciate your suggestion to read the instructions but that leads me into unknown territory and that course of action is not referenced in the installation guide.
I suppose I am trying to understand how to install a piece of software at /var/www/html in Stretch and make it work as it is supposed to.
Apologies if this is long-winded but I am trying to understand how the system functions.
Many thanks.
Mon Jun 11, 2018 9:42 am
Update /etc/apache2/*.conf files and you can move the DocumentRoot to anywhere in your filesystem. It's only set to /var/www/html because the DebIan installer decided to put it there for Jessie and Stretch.
RoddyJoff
Mon Jun 11, 2018 11:49 am
Many thanks Dougie, I’ll give it a go and let you know.
RoddyJoff
Wed Jun 13, 2018 9:04 am
Hi Dougie,
Cracked it!
The following code needed to be added to the /etc/apache2/apache2.conf file.
<FilesMatch \.php$>
SetHandler application/x-httpd-php
</FilesMatch>
Now my .php files work a treat.
