feededandrea
Problem with PiGPIO in javascript
Sun Jun 10, 2018 6:11 am
Hi to all. I was trying to make PWM output for a Led with PiGIO on a ".js" file. So I have this code that works perfect:
var Gpio = require('pigpio').Gpio,
  led = new Gpio(17, {mode: Gpio.OUTPUT,edge: Gpio.EITHER_EDGE});
  led.pwmWrite(value);
<value is between 0 and 255>
But if I want to have multiple outputs, like multiple Leds, I try this:
  led1 = new Gpio(17, {mode: Gpio.OUTPUT,edge: Gpio.EITHER_EDGE});
  led1.pwmWrite(value1);
  led2 = new Gpio(10, {mode: Gpio.OUTPUT,edge: Gpio.EITHER_EDGE});
  led2.pwmWrite(value2);
This for some reason doesn't work. Its like the Led1 works perfect, but the second one, Led2 doesn't do anything, just keeps turned off.
I wish someone could help me, thanks in advance!
joan
Re: Problem with PiGPIO in javascript
Mon Jun 11, 2018 10:12 am
I can't help with javascript.
I can offer a diagnostic suggestion.
On the Pi see if you can trace what pigpio is getting in the way of commands.
In a Pi terminal
# turn on debugs
pigs csi 6
#look at debug info
cat /dev/pigerr &
Then run your javascript.
Mon Jun 11, 2018 10:14 am
Have you tried removing the led1 code and just driving led2 on it own?
feededandrea
Wed Jun 13, 2018 7:09 am
Sorry for not answer before, I'm new here and I didn't find the post.
Joan, as soon as I can, I will try to do that you said.
Heater, I didn't try exactly that, but I invert the Pins, and the other one start working but the other one no.
Fri Jun 22, 2018 12:26 pm
I can't help noticing that you have a comma instead of a semicolon at the end of:
Although I can see that would make much difference.
Also you don't show us what value1 and value2 are set to before that code runs.
