rje
Static IPs for 45 Raspberry Pis!
Fri Jun 08, 2018 7:14 pm
I have 45 Raspbian images, for a hackathon.
I'd like to set a static IP for each of them; however, I would prefer NOT to have to boot each one separately.
I tried adding ip=192.168.8.xx to cmdline.txt file in the boot partition, to no avail. In fact, when I do that, I *think* the Pi can't be reached at all.
Any ideas? Or am I going to have to boot 45 images?
Regards,
Robert
P.S. Raspbian details:
pi@rpi3-aa01:~/sens/vl53l0x $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
Re: Static IPs for 45 Raspberry Pis!
Fri Jun 08, 2018 10:31 pm
Do you know the serial number for each RPi? Or would you need to boot each one to discover that?
ejolson
Sat Jun 09, 2018 3:46 am
Maybe you could edit dhcpcd.conf directly using an SD card reader for each one without booting?
Sat Jun 09, 2018 7:45 am
If we know the serial nunbers we can create a single /etc/dhcpcd.conf for all raspberries, it needs predictable names active to discriminate between each interface.
B.Goode
Sat Jun 09, 2018 9:59 am
Not trying to dodge the question, but a couple of possibly relevant follow-up questions -
Who will be providing/supporting the network infrastructure in the Hackathon venue? Is it provided by the venue, or will you be taking your own 'network in a box'? Relevant because you need to know that the static addresses you assign are valid for the network being used, and that the addresses are allocated to you and not clashing with other users.
Why do you need static addresses?
bensimmo
Sat Jun 09, 2018 10:05 am
Use an AP/Switch/Router and have that set them for you, uplink from there if you need to ?
fred44nl
Sat Jun 09, 2018 10:17 am
that's what I would go for.
boot them all up, and make ip-address reservations in the dhcp-server, based on the mac-addresses.
headless RPi 3B running from usbhdd.
bensimmo
Sat Jun 09, 2018 10:43 am
It all depends on the reasoning and feasibility though.
epoch1970
Sat Jun 09, 2018 11:54 am
Perhaps via a script in rc.local or something like that in addition to cmdline.txt, generating dhcpcd.conf or some systemd network interface?
E.g.
$ cat /proc/cmdline ; X=$(cat /proc/cmdline); X=${X##*elevator=}; X=${X%% *}; echo ; echo "Elevator -> [$X]"
8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  bcm2835_wdt.heartbeat=15 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Elevator -> [deadline]
pksato
Sat Jun 09, 2018 12:17 pm
You need to each SD card have a unique IP or each board have a unique IP?
For SD, a symlink on /etc/network/interfaces.d to a file on /boot. I not sure if work.
For each board, need to use some unique information from hardware, board serial, mac address, eeprom, etc...
And use a init script or some hook on interfaces or other network configuration mechanism.
But, is more easy to setup a dhcp server, on some router or other RPi.
mikerr
Sat Jun 09, 2018 12:57 pm
A more sensible approach might be to just have unique hostnames and access via those.
Raspbian has mDNS, so will respond to hostname.local (raspberrypi.local by default)
ejolson
Sat Jun 09, 2018 5:58 pm
I suspect the idea is for each SD card to have a unique IP address, otherwise you could simply set up a DHCP server with permanent leases keyed to MAC addresses.
Milliways
Sun Jun 10, 2018 6:17 am
The first question I would ask is WHY?
Over a 40 year career as an engineer I have been asked to implement all sorts of improbable "solutions" - in most cases these could be done (often with significant effort) but it is usually easier/cheaper to actually solve the REAL problem, rather than someones idea of a solution.
Static IP addresses are invariably the WRONG solution. (I am old enough to remember the days before DHCP when it was necessary, but a nightmare.)
Sun Jun 10, 2018 8:29 am
Fair comment. /etc/hosts vs a DNS server follows the same argument.
One solution would be a 46th Raspberry (or any other Linux machine) on the network running a local DHCP server (dnsmasq or isc-dhcp-server).
bensimmo
Sun Jun 10, 2018 9:30 am
At that point, set it up as a PiServer and no need to worry about images again.
Could also move to Stretch with one image rather than 45 of them.
Although I want to know what you're doing at the Hackathon with the 45 Pi :-)
pfletch101
Sun Jun 10, 2018 3:50 pm
One proviso: I would entirely agree with your comment if you are talking about a device specifying its own fixed IP address. It is, however, frequently useful and/or necessary to configure a router to assign specific 'fixed' IP addresses to certain devices based on their MAC addresses.
ejolson
Sun Jun 10, 2018 5:26 pm
It would be nice if there was a visible indication when a user is banned. That way people would know whether a one-post thread like this was genuine or simply the registration post of a spammer.
Since there is no indication when a user is banned, it would be helpful if the person who made the original post could give feedback on what they did and how the hackathon turned out.
