Parth1234
Re: How to add java script code into python program?
Fri Jun 08, 2018 7:42 am
B.Goode wrote:
Fri Jun 08, 2018 5:31 am
Have you tested the led with a simple Python+RPi.GPIO script to check that the LED is wired up and working correctly? You could use the script you posted in the first message in this thread.
Hi B.Goode, I have tested led with a simple Python+RPi.GPIO script and it's working correctly ( physical pin #22 is actually GPIO25)
there is no problem in connection. We are missing something in program that why physical led is not working.
Parth1234
Sat Jun 09, 2018 2:15 pm
scotty101 wrote:
Thu Jun 07, 2018 8:47 pm
Hi scotty.. When you will have time, can you test the code
scotty101
Wed Jun 13, 2018 10:20 am
No. Sorry.
You'll have to debug it yourself. Even if I were to get it working on my own Pi, there is no guarantee that that you'll have the same results.
Add a print statement to the On and Off functions.
Check in the python console window to see if the text from your print statement is displayed when you press the button in the web browser.
