i am trying to configure my raspberry pi 3B as a portable plex server, router and access point to act as a standalone wifi network and plex server to use in a holiday home where there is no access to internet
i have largely been following this guide:
https://us.v-cdn.net/6025034/uploads/ed ... wq8tj1.pdf
my workflow was as follows:
installed raspbian stretch
sudo raspi-config
expanded the file system
sudo reboot
sudo apt-get update
sudo apt-get upgrade -y
sudo apt-get install ntfs-3g -y
sudo fdisk -l
sudo nano /etc/fstab
add the line: /dev/sda1 /media/usbhdd1 ntfs-3g gid=pi,uid=pi,noatime 0 0
ctrl+x to save, then y, then return
sudo mkdir /media/usbhdd1
sudo apt-get update && sudo apt-get install apt-transport-https -y --force-yes
sudo wget -O - https://dev2day.de/pms/dev2day-pms.gpg.key | sudo apt-key add -
sudo echo "deb https://dev2day.de/pms/ stretch main" | sudo tee /etc/apt/sources.list.d/pms.list
sudo apt-get update
sudo apt-get install -t stretch plexmediaserver-installer
sudo apt-get install mkvtoolnix -y
sudo apt-get update && apt-get upgrade
sudo apt-get update
sudo apt-get install hostapd isc-dhcp-server -y
sudo nano /etc/dhcp/dhcpd.conf
comment out with #: option domain-name "example.org";
comment out with #: option domain-name-servers ns1.example.org, ns2.example.org;
uncomment line (by removing the #): #authoritative;
add the following lines at bottom:
subnet 192.168.10.0 netmask 255.255.255.0 {
range 192.168.10.10 192.168.10.50;
option broadcast-address 192.168.10.255;
option routers 192.168.10.1;
default-lease-time 600;
max-lease-time 7200;
option domain-name "local";
option domain-name-servers 8.8.8.8, 8.8.4.4;
sudo nano /etc/default/isc-dhcp-server
find the line saying: INTERFACES=""
changed to: INTERFACES="wlan0"
sudo ifdown wlan0
sudo nano /etc/network/interfaces
removed file contents and added the following:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.10.1
up iptables-restore < /etc/iptables.ipv4.nat
saved with ctrl+x, then y, then return
sudo ifconfig wlan0 192.168.10.1
sudo reboot
sudo nano /etc/hostapd/hostapd.conf
interface=wlan0
driver=rtl871xdrv
ssid=PMSPi
channel=6
wmm_enabled=1
macaddr_acl=0
auth_algs=1
wpa=1
wpa_passphrase=raspberry
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
sudo nano /etc/default/hostapd
changed the line: #DAEMON_CONF=""
to be: DAEMON_CONF=“/etc/hostapd/hostapd.conf"
sudo nano /etc/sysctl.conf
added at the bottom: net.ipv4.ip_forward=1
sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
sudo iptables -A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i wlan0 -o eth0 -j ACCEPT
sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
then when i run the following to test it:
sudo /usr/sbin/hostapd /etc/hostapd/hostapd.conf
it is discoverable and connects to external devices fine
then i cancel the test with crtl+c
sudo service hostapd start
then when i run:
sudo service isc-dhcp-server start
i get an error saying that :
job for isc-dhcp-server.service failed because the control process exited with an error code.
see "systemctl status isc-dhcp-server.service" and "journalctl -xe" fir details.
so there must be an error starting the isc-dhcp-server when the pi is booting, so i continue along with:
sudo update-rc.d hostapd enable
sudo update-rc.d isc-dhcp-server enable
to make sure everything starts on boot.
heres the problem,
i start up the pi, the network is discoverable and i can connect devices to it
however my pi internet taskbar icon shows "connection to dhcpcd lost"
and when i visit: localhost:32400/web in my pi browser it starts to load my server,
and then fails and gives a "plex is down for maintenance, dont worry it will be back soon" message
so i cant get into my server to arrange my media etc.
plus, when i connect the pi to my internet connection, it is supposed to still connect to internet via eth0
but it just doesnt connect to internet at all over ethernet
literally tried this for days now and cant seem to find a fix for the issue, must have re-imaged my SD card with a fresh raspbian install over 10 times already
please help?
