I hope this is the best place for this.
Is there a pin can be used, or configured to be used, as an indicator that the pi has finished shutting down?
I'm working on a project with a pi 2 (although I may be swapping it out for a pi 3 at some point, if that matters) that's going to run from an ATX power supply. I'd like the pi to be able to shut everything down when it gets shut down, like a PC does.
Is there any way to do that, or am I going to be forced to keep the pi running forever on the standby rail and control the power-on pin with gpio?
I'd much prefer to run it from the main 5v rail and toggle the power pin when the pi shuts down, but I have no idea if there's any way to tell externally that the safe shutdown is complete.
Any ideas?
[edit] to be honest, I'm not too worried about how long it takes to turn off the power after shutdown, so maybe some kind of pin-flashing program could be run at startup and I could make a circuit to monitor it, then turn off the power a number of seconds after the pin stops flashing?
