But it didn't work. Please send me a proper guideline to follow.
Thank you
Please expand that to provide a basis for informed assistance.it didn't work
Probably. You can check the status of dnsmasq with thisisuru_dhana wrote: The access point was setup. It was showing the 2 arrows in the Desktop. And I could see the AP using other devices also. But when I was trying to connect to it, it said that failed to obtain IP address.
Is this something wrong with the DHCP server setup?
sudo service dnsmasq statusisuru_dhana wrote: ↑Wed May 30, 2018 11:01 am
https://www.raspberrypi.org/documentati ... s-point.md
If I follow the exact same procedure in the above link, it should work for Raspberry pi 3 also right?
The Raspberry Pi can be used as a wireless access point, running a standalone network. This can be done using the inbuilt wireless features of the Raspberry Pi 3 or Raspberry Pi Zero W, or by using a suitable USB wireless dongle that supports access points.
Note that this documentation was tested on a Raspberry Pi 3, and it is possible that some USB dongles may need slight changes to their settings. If you are having trouble with a USB wireless dongle, please check the forums.
Actually it was only intended as a rhetorical device - a figure of speech.
