I just got a RPi 3 B+. I installed Raspbian Strech lite on a SD card using Etcher, but all I get is a solid red light, no green light flashes, no HDMI output, no LAN activity, no LAN connection LED.
Things I connected: USB power supply, SD card, HDMI and LAN cable. The LAN cable is connected to a Switch, I do not see green or yellow lights on either side. No USB Wifi connected.
I put the same SD card into a RPI 1 and it boots, I get LED flashes, I get HDMI output (Terminal), I get LAN activity and connection LED on the switch. I did not reformat the card between taking it out of PI3 into PI1.
How can I get the RPI 3 to boot?
