chexbox
Installing PHP
Tue May 22, 2018 9:50 pm
I am unable to install php.
I tried using this article: https://www.raspberrypi.org/documentati ... /apache.md
sudo apt-get update # worked
sudo apt-get upgrade # also worked
sudo apt-get dist-upgrade # worked as well
sudo apt-get
Here's where things get interesting:
sudo apt-get install php libapache2-mod-php -y
Reading package lists... Done
Building dependency tree
E: Unable to locate package php
E: Unable to locate package libapache2-mod-php
What am I doing wrong?
scruss
Re: Installing PHP
Wed May 23, 2018 1:23 am
If you just
sudo apt install libapache2-mod-php
it should pull in php7 as a dependency.
leiptrstormr
Re: Installing PHP
Wed May 23, 2018 2:54 am
apt-cache search php
This will spit back quite a few packages.
apt-cache search php | less
Slightly more manageable.
sudo apt-get install php7.0
Should be what you're looking for.
Re: Installing PHP
Wed May 23, 2018 4:38 am
Run apt-get update again before doing the apt-get install command. This extra step is needed just once due to something that was changed in a recent upgrade.
chexbox
Re: Installing PHP
Wed May 23, 2018 12:52 pm
I'll try these and reply if anything worked.
Edit: They didn't
sbeland
Re: Installing PHP
Wed May 23, 2018 7:17 pm
why you don't use something light and simple:
sudo apt-get install php-fpm
scruss
Re: Installing PHP
Thu May 24, 2018 2:11 pm
Edit: They didn't
please provide:
  1. the contents of the file /etc/os-release
  2. any error messages you received.
Otherwise, "They didn't" isn't enough to go on.
This from an up-to-date Zero running Raspbian Stretch, running all the apt commands from that article:
$ sudo apt-get install apache2 php libapache2-mod-php
The following additional packages will be installed:
  apache2-bin apache2-data apache2-utils libapache2-mod-php7.0 libapr1
  libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap php-common php7.0
  php7.0-cli php7.0-common php7.0-json php7.0-opcache php7.0-readline
Suggested packages:
  apache2-doc apache2-suexec-pristine | apache2-suexec-custom php-pear
The following NEW packages will be installed:
  apache2 apache2-bin apache2-data apache2-utils libapache2-mod-php
  libapache2-mod-php7.0 libapr1 libaprutil1 libaprutil1-dbd-sqlite3
  libaprutil1-ldap php php-common php7.0 php7.0-cli php7.0-common php7.0-json
0 upgraded, 18 newly installed, 0 to remove and 0 not upgraded.
Need to get 4,559 kB of archives.
After this operation, 17.0 MB of additional disk space will be used.
Do you want to continue? [Y/n]
If you don't get this, you're either running an old OS or there's something broken with your system/network.
