mrmeeseeks
"sudo i2cdetect -y 1" shows full table
Tue May 22, 2018 9:43 pm
hi, I use a raspberry pi zero together with an MPU-6050 module. Both worked perfectly. Today I had to switch off the power for a moment because I had to move furniture, but since then the MPU module is no longer recognized correctly.
sudo i2cdetect -y 1 shows a full table. I've checked the wiring 100 times and now I'm at a loss. Anybody know what might be causing this?
wiring
wiring
photo_2018-05-22_23-35-50 (2).jpg (185.6 KiB) Viewed 756 times
Screenshot of full table
Re: "sudo i2cdetect -y 1" shows full table
Tue May 22, 2018 9:46 pm
That means your SDA line is connected to GND. It's either going to be a bad cable or a solder bridge between SDA & GND
mrmeeseeks
Fri May 25, 2018 12:14 pm
Thank you! Changing wires solved the issue!
