OyarzoPablo
2,8mm wire cable to RPi pins
Mon May 21, 2018 7:12 pm
Do cables like these exist?
I want to connect arcade buttons directly to a RPi.
pcmanbob
Re: 2,8mm wire cable to RPi pins
Tue May 22, 2018 9:53 pm
Well your line
"2,8mm wire cable to RPi pins"
does not make much sense , are you saying you want to connect 2 x 8mm cables to pi gpio or that the switch has a 2.8mm connector ?
From what I have seen for sale in the way of arcade buttons, they normally have terminals for soldering wires to or a terminal that you can push a connector on to.
unless the supplier of the switch is also supplying cables for there connection to the pi gpio I very much doubt anyone else will, so you will probably have to make your own.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
mahjongg
Wed May 23, 2018 12:44 am
considering the pin-pitch of the raspberry PI GPIO port is just 2.54mm I don't see how you could solder 2.8mm thick wires to them, without shorting multiple pins together (this is not a serious reply)....... :mrgreen: :mrgreen: :mrgreen:
I would suggest you screw, or plug in, thinner wires to these buttons.... look at some female to male dupont wires.
I suspect some soldering is needed, or a crimp tool.
Z80 Refugee
Wed May 23, 2018 8:55 am
viewtopic.php?p=526758#p526758
alexeames wrote:
Thu Mar 27, 2014 6:29 pm
Military and Automotive Electronics Design Engineer (retired)
For the best service: make your thread title properly descriptive, and put all relevant details in the first post (including links - don't make us search)!
