jdaie
Minibain for pi 0 w?
Sun May 20, 2018 5:45 am
Does anyone knows where to find Minibain for pi 0 w? I'm working on a project base on pi 0 w, it takes one and a half minutes to boot up a raspbain. Minibain only needs 10 seconds. But it seems that there is no wifi driver installed :?
Re: Minibain for pi 0 w?
Sun May 20, 2018 6:56 am
The MiniBian latest release pre-dates the ZeroW and is over 2 years since last updated:
https://sourceforge.net/projects/minibi ... rce=navbar
It is based of end of life Raspbian Jessie have you fully updated ??
sudo apt-get update
sudo apt-get dist-upgrade
RPi 4B 4GB (SSD Boot)..
jdaie
Sat May 26, 2018 11:01 am
sudo apt-get update
I have tried to fully update and upgrade, the system then failed to boot up after that. The screen stop with the colorful frame which shows at the beginning of Raspbain startup.
ejolson
Sun May 27, 2018 5:02 am
There are currently two versions of Raspbian: the full-fat version and lite. Unlike with milk, the lite version is quite good.
Minibian stopped being updated about the time that the lite version was made available. The lite version is officially supported and in my experience boots fast.
Gavinmc42
Sun May 27, 2018 7:43 am
Try piCore if you want a fast booting Linux.
http://forum.tinycorelinux.net/index.ph ... ,57.0.html
To go faster means optimizing Buildroot
http://www.jumpnowtek.com/rpi/Raspberry ... droot.html
Faster again is baremetal, I prefer Ultibo these days, but it may not yet do what you want.
https://ultibo.org/
I have heard systemd will boot the kernel in about 2secs, the user space stuff takes the rest of the time.
http://intestinate.com/pilfs/guide.html
Less than 2 seconds and you need to write your own bootcode/start.elf.
https://github.com/christinaa/rpi-open-firmware
Of the above only piCore has WiFi support?
Alternatively, start with Raspbian Lite and remove most of the stuff.
And use a A1 rated SD card?
I'm dancing on Rainbows.
mikerr
Sun May 27, 2018 9:43 am
There's a slightly more up to date version at https://sourceforge.net/projects/minibianwifi/
which works on PiZeroes with Realtek/Ralink wifi dongles
You will need wifi drivers for PiZeroW :
wget https://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-brcm80211_20161130-3+rpt3_all.deb
dpkg -i firmware-brcm80211_20161130-3+rpt3_all.deb
and a firmware update:
rpi-update ef7621d91cb58ccc856c3c17ddda28685edd23f3
Just uploaded a version with that already done at https://sourceforge.net/projects/minibianwifi/
jdaie
Thu Jun 07, 2018 8:34 am
It works! Thank you Mikerr !!
