DaveCummings
Running DOS Batch Files
Fri May 18, 2018 10:31 am
Hello All,
I am sure this has been asked before, but would like to run a batch file against a CSV file. The first few lines are:
prompt %p$g
CLS
DCARS Radar Processing.
STAGE 1
ECHO.
Assigning Aircraft Registrations to HEX/MODES codes.
This may take some time....
rem copy d:\processor\incoming\*.csv d:\processor\backups\
process -r -i "d:\processor\incoming\*.csv" "EC-402" "EC-402,Airbus Military,A400M,,Airbus Military,,,Yes"
process -r -i "d:\processor\incoming\*.csv" "EC-404" "EC-404,Airbus Military,A400M,,Airbus Military,,,Yes"
process -r -i "d:\processor\incoming\*.csv" "EC-CCE" "EC-CCE,Cessna,414,,Private,,,Yes"
process -r -i "d:\processor\incoming\*.csv" "EC-CGV" "EC-CGV,Piper,PA-28 180 Cherokee,,Private,,,Yes"
process -r -i "d:\processor\incoming\*.csv" "EC-CHE" "EC-CHE,Beech,King Air A100,,Secretariat of Civil Aviation,,,Yes"
process -r -i "d:\processor\incoming\*.csv" "EC-CJF" "EC-CJF,Cessna,337G Super Skymaster,,Private,,,Yes"
process -r -i "d:\processor\incoming\*.csv" "EC-CSQ" "EC-CSQ,Piper,PA-28R 200 Cherokee Arrow II,,Private,,,Yes"
process -r -i "d:\processor\incoming\*.csv" "EC-CZV" "EC-CZV,Aerotek,Pitts Special S-2A,,Private,,,Yes"
process -r -i "d:\processor\incoming\*.csv" "EC-CZZ" "EC-CZZ,Reims/Cessna,FR172J Rocket,,Private,,,Yes"
Can anyone advise if this would be possible?
Re: Running DOS Batch Files
Fri May 18, 2018 10:38 am
Looks like that script is calling a program called "process" which is probably the bit that is going to be difficult to replicate under Linux (rewriting the script in bash would probably be fairly easy). Have you got a Linux version of it? Or know what it does?
n67
Fri May 18, 2018 10:42 am
Yeah, my first reaction on seeing this thread was the usual "Oh, you can't run a batch file under LInux, etc, etc, etc:", but then I noticed that this was posted in the Windows 10 for IOT section, so it really has nothing to do with Linux.
I, of course, know nothing about Windows 10 for IOT, but I would guess that there is probably some kind of support for DOS batch files there. If not, then one may have to convert it to PowerShell, which is the latest/current version of the DOS batch language.
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
DaveCummings
Fri May 18, 2018 10:48 am
REPLACE is actually a program called FART :
http://www.majorgeeks.com/files/details/fart.html
Fri May 18, 2018 12:27 pm
So could be replaced by grep and sed I suspect.
If that is majority of the work, then you could easily rewrite the batch file to run under Linux. I cannot comment on using it under Win10IoT, I know nothing.
Fri May 18, 2018 1:32 pm
This will not run in Windows 10 IoT Core OS, you need a x86 Windows Desktop OS !
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
n67
Fri May 18, 2018 2:07 pm
I don't get all these references to either "REPLACE" or "F***", since neither appear in the original posted batch file (*). What exactly ARE we talking about anyway?
Also, REPLACE is an old-school DOS command (and presumably still present in WIN 10), not that that has any relevance to this either.
(*) The batch file seems to be repeated calls to something called "process" - whatever that is.
Epmu Sn!
Fri May 18, 2018 2:37 pm
Good point. I brought up the "process" command in my first post, but then someone decided to chime in with replace and sidetracked everything.
Z80 Refugee
Sat May 19, 2018 8:05 am
At first glance, it looks like the "process" command takes parameters which specify character string replacements in a file. These things can be accomplished easily in Linux.
Military and Automotive Electronics Design Engineer (retired)
For the best service: make your thread title properly descriptive, and put all relevant details in the first post (including links - don't make us search)!
ptrex
Tue Jul 03, 2018 8:39 am
Why don't you try Powershell ...
viewtopic.php?f=105&t=217279
Here is an example on how to read CSV files using Powershell :
https://www.petri.com/powershell-import ... -text-file
Hope this can help ...
rgds,
ptrex
