Dhy1
Raspberry freezes
Fri May 18, 2018 7:27 am
I use the raspberry to keep online an online radio via icecast .. after a while the radio is online it happens that the raspberry of blocks, the online radio no longer goes and it is impossible to be able to access via ssh .. the rappberry is connected to the internet with wifi ..
what can it be ? can it be the fault of the wifi and I have to connect with the LAN?
thanks in advance: D
lmarmisa
Re: Raspberry freezes
Fri May 18, 2018 9:28 am
You should determine if your RPi really freezes or is unable to connect to wifi when that event happens.
Take a look at the log file /var/log/syslog. Is there any info related to wifi while your RPi is not working properly?. This command could be useful:
grep wlan0 /var/log/syslog
If your RPi really freezes, try using a better power supply unit.
https://www.raspberrypi.org/documentati ... /README.md
