ericcooper
how to connect to pins that are already used by a HAT?
Thu May 17, 2018 4:09 pm
I have a Pi Zero W with a HAT that covers all the GPIO pins with its header. I'd like to attach yet another device to some of those pins. All I can think of is to solder to the stubs of the header pins on the back of the Pi. Is there a better method?
mahjongg
Re: how to connect to pins that are already used by a HAT?
Thu May 17, 2018 4:37 pm
Or Alex Eames Full_phat
Or a dozen other solutions.
Like a band cable with multiple female isolation displacement connectors.
ericcooper
Thu May 17, 2018 7:15 pm
Thanks for these suggestions. This is for a small battery-powered system, so the smallest shim solution is the most attractive for my application.
bensimmo
Thu May 17, 2018 7:31 pm
Or, depending on the hat, if not soldered or not soldered yet, then use a longer pin riser.
E.g. https://www.adafruit.com/product/2223
Or solder, as you say to the pins (or rear side pins).
What hat is it ?
ericcooper
Thu May 17, 2018 8:57 pm
bensimmo wrote: What hat is it ?
It's a pHAT of my own design (actually designed by a real EE; I did the software and overall architecture) that has two radios (915MHz and 2.4GHz), LiPo power management and charging, plus some assorted goodies like ADC, RTC, and accelerometer.
