ericcooper
how to connect to pins that are already used by a HAT?
Thu May 17, 2018 4:09 pm
I have a Pi Zero W with a HAT that covers all the GPIO pins with its header. I'd like to attach yet another device to some of those pins. All I can think of is to solder to the stubs of the header pins on the back of the Pi. Is there a better method?
mahjongg
Re: how to connect to pins that are already used by a HAT?
Thu May 17, 2018 4:37 pm
Or Alex Eames Full_phat
Or a dozen other solutions.
Like a band cable with multiple female isolation displacement connectors.
ericcooper
Thu May 17, 2018 7:15 pm
Thanks for these suggestions. This is for a small battery-powered system, so the smallest shim solution is the most attractive for my application.
bensimmo
Thu May 17, 2018 7:31 pm
Or, depending on the hat, if not soldered or not soldered yet, then use a longer pin riser.
E.g. https://www.adafruit.com/product/2223
Or solder, as you say to the pins (or rear side pins).
What hat is it ?
ericcooper
Thu May 17, 2018 8:57 pm
bensimmo wrote: What hat is it ?
It's a pHAT of my own design (actually designed by a real EE; I did the software and overall architecture) that has two radios (915MHz and 2.4GHz), LiPo power management and charging, plus some assorted goodies like ADC, RTC, and accelerometer.
Who is online
Users browsing this forum: No registered users and 6 guests
