lammyoflyd
Hotspot -> pi as client -> pi network -> personal devices
Mon May 14, 2018 10:58 pm
I'm attempting to set up a pi to function in much the same way as a TP-Links TL-WR710N can in WISP router mode. My pi connecting to a client network, and then also creating a private network so that i can share internet access between multiple devices. Having an extra Wi-Fi dongle to the onboard one is not a problem, and I have one in mind which uses the RT5370 chipset.
I’ve already attempted many tutorials, including https://www.raspberrypi.org/documentati ... s-point.md and https://makezine.com/projects/browse-an ... or-router/ however so far all have failed, and I lose all connectivity to any network from my pi.
To add extra complication to the project, I’d also like to reserve 1 IP address for a Kodi setup sitting on a different pi, and a samba/NAS share which is only accessible from within the private section of the network.
Does anybody know of a good tutorial which would allow me to set this up reliably? Or is someone who has expertise in the subject able to write a how-to/guide/tutorial on how to do some/all of these tasks?
SurferTim
Re: Hotspot -> pi as client -> pi network -> personal devices
Tue May 15, 2018 11:37 am
I use the NAT access point setup here.
I can use a usb dongle for either the client or ap, depending on the dongle. Some usb dongles don't do the ap mode.
It takes a bit more setup to use a wifi device as the client (WAN). Did you split the wpa_supplicant file?
/etc/wpa_supplicant/wpa_supplicant-wlan0.conf
and
/etc/wpa_supplicant/wpa_supplicant-wlan1.conf
I also needed to insure they booted using the correct interface names. Change the mac addresses to your requirements.
Create file /etc/udev/rules.d/72-static-name.rules
ACTION=="add", SUBSYSTEM=="net", DRIVERS=="?*",
ATTR{address}=="00:c0:ca:96:d8:8b", KERNEL=="w*",NAME="wlan0"
ATTR{address}=="b8:27:eb:1e:56:52", KERNEL=="w*",NAME="wlan1"
Also you must install a masquerade for your WAN wifi device.
Flip_side
Sat May 19, 2018 4:04 pm
I have been able to configure the Raspberry Pi as both an access point and a wifi client using the built-in wifi only. I have followed the instructions on this page: https://github.com/peebles/rpi3-wifi-station-ap which has has worked great for the raspbian stretch 2017-11-29 version.
However, with the new raspbian 2018-04-18 version, some things have changed in the way wifi works on the Raspberry Pi and these instructions no longer work as before.
Could anyone explain to me what changes I should make in my configuration for it to work as before?
