davetedd
Extra time mystery with time.strftime
Mon May 14, 2018 11:07 am
I have created a python program for recording the time at which a warning signal is given and the start signal 5 minutes later using the command in the title for a dinghy racing starting procedure.. This works fine when run using the python command with the system up and running and the RTC in the system operational.
If however I put this program into rc.local so it loads on boot up then when it is run the warning signal time records ok but the start signal is shown as 5 mins 23 secs later rather than the actual 5 mins. The system time and RTC time give the same time when checked. Does anyone have any ideas? Any suggestions would be appreciated.
gordon77
Re: Extra time mystery with time.strftime
Mon May 14, 2018 11:59 am
Can you upload your code so we can see it?
davetedd
Mon May 14, 2018 4:44 pm
How do I add code to my reply? I have not been able to find an answer to that query. There is no "insert" function, such as is used in emails?
Mon May 14, 2018 5:16 pm
Cut'n'paste is your friend.
Wrap the code in code tags [code]... paste your stuff here ...[/code]
This is a hippy & doctor free zone.
davetedd
Tue May 15, 2018 8:12 am
Thanks for that help - will post it later.
davetedd
Wed May 16, 2018 8:59 am
This is testusb.sh
#!/bin/bash
test -e /media/usb?/raceflag?.py
if [ $? -eq 0 ]
then
sudo python /media/usb?/raceflag?.py
else
sudo python /home/pi/programs/race/insmem.py
fi
exit 0
and this is rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
printf "\n testline" &
./bin/testusb.sh &
exit 0
The actual race program is raceflag1.py. If the unit is turned on without the right usb stick inserted a warning is given.
Wed May 16, 2018 6:06 pm
What are all of sudos doing there? DO NOT use sudo unless you need to elevate privileges. BTW, /etc/rc.local runs as root anyway so nothing in it needs sudo anyway.
Also please post your python code.
davetedd
Fri May 18, 2018 7:27 am
The problem was caused by the system time taking some time to update from the rtc after bootup. Once that was done the timing was correct.
So a solution will be to force an update before the program can be run.
On the sudo issue the commands are in a bash script which runs inside rc.local. If I leave them out then the usb memory stick detection feature does not work. I had to do that because the test command does not function if put directly into rc.local. The latter aborts if any command in it gives a false answer, so any test which can give a true or false answer does not operate. I tried some work arrounds but no result.
Anyway ok now thanks for your comments.
Fri May 18, 2018 7:48 am
Add uid=pi,gid=pi to the options on the mount command for the USB stick and it won't need sudo if you're running as the pi user.
mount -o uid=pi,gid=pi /dev/sda1 /mount/point/here
Return to “Advanced users”
