pi9
moving mysql database to a usb drive
Sat May 12, 2018 2:05 pm
Hi
I need to move one database to a USB drive rather than running it off the main sd card and shortening its life. There are many articles on other forums on how to move all the databases using the my.cnf file, but I just need certain databases. Is that possible?
Re: moving mysql database to a usb drive
Sat May 12, 2018 3:03 pm
Close MySQL, move files from /var/lib/mysql to /new/directory, update /etc/mysql/my.cnf change all instances of /var/lib/mysql to /new/directory, save it. Restart MySQL, grab a beer, celebrate.
Simples.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Sat May 12, 2018 3:21 pm
Except, Dougie seems have drunk his beer before posting and hence gives exactly the answer you did not want. That is, how to move all the mysql databases.
I suspect that it is not possible to move individual databases from what I have read. For example: http://etutorials.org/SQL/MySQL/Part+II ... Directory/
However, all is not lost. You could run more than one instance of MySql, each configured with it's own database location. Which can of course be different.
You will have to change the configuration of the second or third... instances to use different port number to listen on.
Or, perhaps, you could move the file(s) for a database out of the normal data directory to somewhere else and then create symbolic links in the data directory pointing to the new database files locations.
Do back up your data before messing with any of this, if it's important.
Sat May 12, 2018 3:46 pm
Looks like you can move just one database with
sudo mv /var/lib/mysql/DATABASENAME /full/path/to/new/db/.
sudo ln -s /full/path/to/new/db/DATABASENAME /var/lib/mysql/DATABASENAME
MQTT Evangelist
Sat May 12, 2018 6:04 pm
Excellent Dougie. Can we have that beer now?
pi9
Sat May 12, 2018 6:35 pm
lol. ok i'll try that before anyone grabs a beer
Sat May 12, 2018 6:39 pm
I grabbed a beer, created a new database, inserted a row then moved it to /tmp.
The interesting thing was the folder & files in /tmp got deleted when I dropped the database after my experiment.
I'll be on the Yeni-Rakı when the Eurobore Song Contest starts.
MQTT Evangelist
pi9
Sat May 12, 2018 7:19 pm
Isn't it supposed to be like that? The database no longer exists. right?
I am not sure what you were trying to say.
Sat May 12, 2018 8:54 pm
I didn't expect it to follow the symbolic link and delete the underlying database in /tmp.
MQTT Evangelist
pi9
Tue May 15, 2018 2:53 am
I just tried it. It works
(Y)(Y)(Y) <- 3 thumbs up
pi9
Wed May 16, 2018 2:59 am
Following up on my question earlier. I mounted the USB stick using:
sudo mount -t vfat /dev/sda1 /mnt/usb
and created the symbolic link. All is well except that when I try to create a table I get ERROR1005... can't create table (errno:13). I changed the permissions on database folder chmod +777 /mnt/usb/mydb but i still get the same thing. When I try to create the table on the original database I don't have any issues.
Wed May 16, 2018 6:03 am
Reformat the stick as ext4 or mount it with uid=mysql to allow the mysql task to access files on your vfat filesystem.
MQTT Evangelist
pi9
Fri May 18, 2018 1:03 am
I tried different variations for the mount command, but I couldn't figure it out.
i tried uid=mysql and tried UUID=mysql and -u mysql, but it doesn't work.
Should I substitute mysql with some user name? I run mysql as root when I am creating the tables, but my applications have their own users to login. I am leaning towards running keeping the USB with fat in case I decide to plug it in windows later down the line. I don't want to format it by mistake.
rpdom
Fri May 18, 2018 5:00 am
sudo mount -t vfat -o uid=mysql /dev/sda1 /mnt/usb
pi9
Sat May 19, 2018 1:46 am
Thanks. That resolved my issue. I am now able to create tables.
For other people's reference, this is what I put in /etc/fstab:
/dev/sda1  /mnt/usb  vfat  rw,users,uid=mysql  0 2
Return to “Other languages”
Who is online
