nl3prc
raspberry pi b+ to raspberry pi 3
Sat May 12, 2018 1:00 pm
Hoi
ik heb met succes een rasbian jessie draaien op een raspberry pi b +
echter als een maat van me een copie probeert op zijn raspberry pi 3 slaat hij tijdens laden van de kernel vast
weet iemand hier iets op
nl3prc
Re: raspberry pi b+ to raspberry pi 3
Sat May 12, 2018 1:02 pm
i have rasbian on a raspberry pi b+ but when i tried to run the same image on a raspberry pi 3 it crashes on kernel load
is the a way to work around that
thanks
Sat May 12, 2018 1:04 pm
Try booting a copy of Raspbian 2018-04-18.
gkaiseril
Sat May 12, 2018 4:13 pm
RPF recently released the Raspberry Pi 3B+ so any reference to a RPi B+ is not clear since there is now the Raspberry Pi B2+ and the Raspberry Pi B3+. The B3+ has new controllers for the Ethernet and Wireless which uses different software drivers. This means if one is using the Raspberry B3+ the newest version of Raspbian needs to be used and if you are using NOOBs you also need to use the most recent version. Older versions might boot but there will power usage issues and network connections issues due to the use of old drivers.
You need to provide very clear information as to the exact model of Raspberry Pis you are using and not any abbreviated name.
Sat May 12, 2018 4:47 pm
Raspberry Pi B2+ does not exist :shock:
Raspberry Pi B3+ does not exist :shock:
https://en.wikipedia.org/wiki/Raspberry ... ifications
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
NL1TD
Sat May 12, 2018 5:10 pm
Hi all,
Well its about mine PI. I have de PI3 model B and NL3PRC he haves an older model I think then I have.I have tried to load the kenrel serveral times but it keeps hanging at boot up with the messages "Critcal error couldnt load the kernel or mount the kernel"
Now as I think it looks to me that it is impossible to load an older kernel in a newer machine. Am I right or wrong ?
Anyone haves an idea about it?
Thanks.
Theo.
Sat May 12, 2018 5:42 pm
Please re-read what YOU posted above as you have written something completely different from what the RPi models are named :D
adieu
davidcoton
Sat May 12, 2018 8:30 pm
Hi all,
Thanks.
Theo.
Older kernels are likely to fail on hardware introduced after the kernel release.
Particularly it is known that the Pi3B+ needs an updated OS (in several respects).
Assuming Raspbian Stretch without NOOBS (or PINN or Berryboot), boot an older Pi with the card. Do:
sudo apt update
sudo apt full-upgrade
Shut down, transfer card to new Pi, boot and it should work.
Older Raspbian, or NOOBS: can be updated but it's easier to start again with latest Raspbian Stretch, Full or Lite, with or without NOOBS (but PINN is an impovement if you really need multiple OSs or the repair facility).
Other OSs? All bets are off.
Signature retired
nl3prc
Sun May 13, 2018 1:13 am
I have updated the kernel and distro to the latest version it still works on mij raspberry PI B+
nl3prc
Wed May 16, 2018 7:38 am
I,m sorry to say that it stl is not running on a raspberry pi 3 b+
mfa298
Wed May 16, 2018 8:11 am
It would likely help if you described more about the setup.
How and when does it crash.
Which OS version are you runing
are you using NOOBs or PINN
etc.
Also please be clear what model your going from and two. You've mentioned two or three model types in this post For identification this may help - there are small physical changes between most models https://www.raspberrypi.org/products/ or for the pis you can make boot you can use the revision code https://www.raspberrypi.org/documentati ... /README.md
nl3prc
Wed May 16, 2018 1:55 pm
I downloaded rasbian jessie in 2016 and made a dist upgrade 2 days ago https://www.raspberrypi.org/blog/raspbian-stretch/
On my raspberrypi 1 b+ everything works but when i made an image for a vrind to run on the pi 3 b+ its not booting.
debian version went from 8 to 9.4
nl3prc
Fri May 25, 2018 2:25 pm
Return to “Advanced users”
