aplocher
Converting Raspbian (Pixel) into Raspbian Lite after installation
Fri May 04, 2018 2:03 am
Are there a specific set of packages that makeup the difference between Raspbian (Pixel) and Raspbian Lite?
I accidentally loaded up the full Raspbian on my SD Card and configured everything exactly how I wanted. It wasn't until I plugged an HDMI cable in to check something that I realized I didn't do Raspbian Lite and I have an unwanted GUI loaded.
Is there an easy way to "downgrade" to Raspbian Lite?
klricks
Re: Converting Raspbian (Pixel) into Raspbian Lite after installation
Fri May 04, 2018 4:56 am
Just find boot options menu in sudo raspi-config and set boot to CL.
If you need more space on your SD card then delete some of the heavy packages...... LibreOffice, Wolfram etc
rpdom
Fri May 04, 2018 5:15 am
I'm assuming (because you mentioned an SD card), that you are talking about Raspbian on a Pi and the differences between the full Desktop version (which is not called "Pixel") and the Lite version.
There are quite a few package differences. I haven't tried downgrading (I only use Lite anyway), but I think removing raspberrypi-ui-mods and then doing apt-get autoremove might clear the desktop packages. Otherwise removing xserver-xorg should do it.
Fri May 04, 2018 8:55 am
If you are not worried about SD card space, simply turn off booting to desktop in raspi-config.
Return to “Raspberry Pi OS”
