Hello guys
I'm curious, I'm building something with a Raspberry Pi 3B+, can a 5V 5A power supply be used as well?
Thank you in advance.
Future proofing.HawaiianPi wrote: ↑Mon Apr 30, 2018 6:31 pmNot sure why you would want to use a PSU that strong, but if it's well regulated (stable 5V output) it should work fine.
As noted above, providing more current than a Pi needs will not be a problem electrically but, if there's ever a short, that could cause more damage than when providing a lower current. The Pi over-current protection fuse (where included) will offer some protection so long as you use the power input connector.
Except that future Pi computers may actually need less power, rather than more (the current Pi models are using 40nm tech).
I see the opposite trend. Each Pi uses more than the last (with the exception of the zero series)HawaiianPi wrote: ↑Mon Apr 30, 2018 8:07 pmExcept that future Pi computers may actually need less power, rather than more (the current Pi models are using 40nm tech).
Results of the past are not an indication of the future.Imperf3kt wrote: ↑Mon Apr 30, 2018 10:01 pmI see the opposite trend. Each Pi uses more than the last (with the exception of the zero series)n67 wrote: Except that future Pi computers may actually need less power, rather than more (the current Pi models are using 40nm tech).
Just look at the Pi3B+, even after undoing the overclocking, it still uses significantly more power than the Pi3B and frankly, is why I won't be buying one.
I was under the impression that the difference between the 2837A1 (?) and the 2837B0 was mirroring the same chip and then turning it over in the package so that all the connections are in the same--relative--positions. In theory, couldn't a 2837B0 be put on a Pi3B or Pi2Bv1.2 PCB and would work? (Wouldn't get as much thermal dissipation, though.)
I have been willing to see a 1.2GHz Pi4B. At 1.4GHz, that's just icing on the cake. So...yeah. I expect the power requirements won't go up. Whether it goes down will depend on other features.The next iteration is sure to use a more frugal technology.
I would be very surprised if the next PI would consume considerably more power than the PI3B+, all that heat has to go somewhere. 5A is IMHO out of the question.
FUD.mahjongg wrote: ↑Mon Apr 30, 2018 5:56 pmExcept that much more smoke escapes when you manage to create a short, and not to speak of what will happen when you switch the supply on, and for a short while the output goes over 6Volt (Hint: much more smoke).
the PI should get no more than 5.1 Volt.
https://www.raspberrypi.org/help/faqs/#power
That's because all current models are still built on 40nm tech. If the RPF wants to continue making more and more advanced $35 computers (or even cheaper computers), then that has to change. The next generation will likely be built on a smaller process node (smaller transistors) which will improve performance while reducing power consumption and manufacturing cost.
You are assuming the Raspberry Pi foundation intends to release a more powerful "$35 computer" for every release.HawaiianPi wrote: ↑Tue May 01, 2018 7:13 amThat's because all current models are still built on 40nm tech. If the RPF wants to continue making more and more advanced $35 computers (or even cheaper computers), then that has to change. The next generation will likely be built on a smaller process node (smaller transistors) which will improve performance while reducing power consumption and manufacturing cost.
I was actually surprised they're still using 40nm (current gen Intel and AMD x86 processors are 14nm).
That has been the case for most of the $35 price point releases.
It will be necessary to reduce both power consumption and manufacturing cost. It will have to happen someday.
Nothing much... Just comments from Eben Upton and the recent hardware releases from Broadcom using a 28nm node. Certainly no clues *there*...
Are you implying that having 5A available means that I would expect the next Pi uses all of that? That is just silly. I don't. I doubt any model Pi will ever be designed to require more than 2.6AHawaiianPi wrote: ↑Tue May 01, 2018 6:04 pmThat has been the case for most of the $35 price point releases.
But yes, it is speculation. Just like needing a 5A PSU for future generations is speculation (disregarding the fact that you can't push 5A through a micro USB connector).
I wasn't implying anything. I was just responding to n67's reply, which said:
Yes but, "if you use the correct hardware" is the problem. I know what the spec says, now show me a micro USB part that is actually rated that high.
A properly designed regulated power supply won't surge to 6v. I made my own linear regulated psu using two 2N3055's LM723 and a crowbar for OVP. Delivers 4 amps at 5.1v, crowbar at 5.7v.mahjongg wrote: ↑Mon Apr 30, 2018 5:56 pmExcept that much more smoke escapes when you manage to create a short, and not to speak of what will happen when you switch the supply on, and for a short while the output goes over 6Volt (Hint: much more smoke).
