JulesD97
RPI as an acces point with USB wifi dongle PROBLEM
Mon Apr 30, 2018 10:55 am
I just followed this tutorial on how to make your rpi as an access point. (https://www.raspberrypi.org/documentati ... s-point.md)
After going through all the steps the pi won't show up on my computer under networks.
I followed al the steps but the problem is I am using a raspberrypi model B so i use a usb wifi dongle.
I am using a EDIMAX EW-7811Un dongle.
Can anyone tell me the changes you have to make when using a wifi dongle?
Thanks in advance
Jules :)
Re: RPI as an acces point with USB wifi dongle PROBLEM
Mon Apr 30, 2018 11:50 am
Thanks in advance
Jules :)
Did you install the Firmware / Drivers for the WiFi Dongle ?
JulesD97
Mon Apr 30, 2018 11:59 am
Euhm i don't remember doing so. where can i find these? thank you for replying, I know I'm a noob :p
MrEngman
Mon Apr 30, 2018 12:03 pm
Thanks in advance
Jules :)
The Edimax EW-7811Un wifi uses the 8192cu driver so the driver/firmware should not need installing as it is included in the Raspbian images.
JulesD97
Mon Apr 30, 2018 12:17 pm
When i run sudo iwlist wlan0 scan the connections in my house show up so the dongle works. I just don't know if i missed something :/.
JulesD97
Mon Apr 30, 2018 12:25 pm
I read somewhere that the problem might be that i am using the new raspbian stretch and not the old rapsbian jessie do you think this might be the problem? And if so what is the best solution?
SurferTim
Mon Apr 30, 2018 12:59 pm
I don't have a problem using an Alfa usb module.
Check the status of hostapd.
sudo service hostapd status
It should show active (running). If it doesn't, you have a problem.
Sometimes starting the service manually will give you more info.
sudo service hostapd stop
sudo hostapd /etc/hostapd/hostapd.conf
JulesD97
Mon Apr 30, 2018 1:05 pm
It says Active (exited)
in the .conf file it says
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
JulesD97
Mon Apr 30, 2018 1:15 pm
My rpi shows up on my wfi networks on my pc now but i can't seem to make a connection just jet. the wifi simbol keeps flashing like it is connecting. when i try ssh via terminal and the static ip this shows up: connect to host 192.168.4.1 port 22: Network is down.
It seems like i'm not getting trough. when i try to connect the following shows up on the pi
wlan0: STA........... WPA: pairwise key handshake completed (RSN)
JulesD97
Mon Apr 30, 2018 1:40 pm
I think i got it running but the thing is that i have to run the sudo hostapd /etc/hostapd/hostapd.conf command before it starts working verry strange how can I make it that when i plug the pi in it automatically starts sending out the signal?
SurferTim
Mon Apr 30, 2018 8:14 pm
If it doesn't show up. try stopping the service for a few seconds, and then restart it
wait 5 seconds
sudo service hostapd start
See if it shows up. If it does, then open /etc/rc.local with a text editor and add this before the "exit 0"
sleep 5
