dverleysen
Raspberry Pi ZERO W no wifi interface found...
Sat Apr 28, 2018 6:15 pm
I bought this week a Raspberry Pi ZERO W and it's a struggle to config that thing! Tried to setup as a headless device but I had to much problems so I bought some adapters to connect screen and keyboard.
But I cannot find any wifi icon or connection, when I run raspi-config I get the message that there's no wireless interface found... WHAT?
Hereby some screenshots and a shot of the back of the device
https://photos.app.goo.gl/3UKAkJiHcweo8bLd7
I have to enable the wireless interface??
The device that i've bought.
https://www.kiwi-electronics.nl/raspber ... 0W&lang=en
Thanks for the tips!
https://www.linkedin.com/pulse/harvesting-tomatoes-version-20-didier-verleysen/
Re: Raspberry Pi ZERO W no wifi interface found...
Sat Apr 28, 2018 7:18 pm
Are you sure it's a ZeroW a cat /sys/firmware/devicetree/base/model;echo command will tell you.
pi@mercury:~ $ cat /sys/firmware/devicetree/base/model;echo
Raspberry Pi Zero W Rev 1.1
pi@mercury:~ $
dverleysen
Sat Apr 28, 2018 7:23 pm
@dougielawson that is what I see on the back --> https://photos.app.goo.gl/3UKAkJiHcweo8bLd7
And when I run "cat /sys/firmware/devicetree/base/model;echo"
I get = Raspberry Pi model B Rev 2 ????????????????
Sat Apr 28, 2018 7:55 pm
Then your SDCard is full of junk.
Get latest 2018-04-18 Raspbian and Etcher. Use Etcher to write Raspbian to your SDCard.
https://downloads.raspberrypi.org/raspbian_latest
https://etcher.io
dverleysen
Sat Apr 28, 2018 8:02 pm
@DougieLawson it's this version created with Etcher.
Similar issue like this? viewtopic.php?t=178362
I just downloaded the image again, and use etcher to flash the card. = Same issue :(
Sat Apr 28, 2018 8:40 pm
HawaiianPi
Sun Apr 29, 2018 2:39 am
Then you need to return your Pi0W for an exchange. It's defective (SoC was not properly programmed).
stepnwright
Sun May 27, 2018 5:41 pm
I am having a similar problem with my Pi Zero W which I have been trying, frustratingly for 3 months, to get wifi to work headlessly.
I was not getting it to connect headlessly to my network so I spent extra money to get HDMI cables etc to see what was going on. I found that no wifi interface found. So I sent it back and got a replacement.
So this weekend I have installed 2018-04-18-raspbian-stretch.img on the new pi. Plugged it all in and seen it come up on the monitor with the wifi interface working. However, I do not have a keyboard to plug into the pi and enter the wifi password(and I don't want to spend any more money on this project). So I removed the card, added a wpa_supplicant.conf file with the necessary information. inserted back into the pi and restarted.
It booted successfully however the wifi now says no wifi interface found. I tried this twice with a newly imaged os and the same thing happens. So it appears the wpa_supplicant.conf file is causing some major issue with the wifi interface.
Surely, this can't be just a few of us this is affecting? I am about to send all of the pi stuff back to get a refund. I have wasted too much time on this project already. Unless someone has a simple fix.
Please help
Steve
davidcoton
Sun May 27, 2018 8:46 pm
What is in your wpa_supplicant file?
What is the network security type?
Does the network hide its SSID?
Signature retired
