BirchJD
Reading OBDII Trouble Codes & Descriptions Using Python On A Raspberry Pi
Sat Apr 28, 2018 4:47 am
I have written a Python script to read trouble codes from a car ECU and look up a human readable description for the codes. I will OpenSource the Python script on GitHub a bit later today here:
https://github.com/BirchJD?tab=repositories
Following are some videos about the project:
https://youtu.be/3HDXC85-MFU
Using a Raspberry Pi to Talk OBDII to an ECU Via an ELM327 Device
https://youtu.be/NvYXtQmOYDw
Brief Overview of CAN BUS Preparation For ODBII
https://www.youtube.com/watch?v=JHP_yXznV2Q
http://www.newsdownload.co.uk/
BirchJD
Re: Reading OBDII Trouble Codes & Descriptions Using Python On A Raspberry Pi
Sun Apr 29, 2018 8:48 pm
The Raspberry Pi OBDII Python script is now communicating and getting all valid PID data using a Python Class. Source code will be updated on GitHub.
https://youtu.be/JOTc_qhx6rQ
BirchJD
Sat May 05, 2018 10:46 am
The OBDII Python application now has the start of a GUI added. The next update should have most of the GUI complete and a custom Raspberry Pi device to run on.
Open Source Raspberry Pi OBDII Python Application - Start Of GUI Coding
https://youtu.be/fXxJ4rSZiI8
BirchJD
Thu May 17, 2018 7:37 pm
Rumee
Mon Oct 15, 2018 7:52 am
How can i get data from OBD2 to raspberry pi without using GUI.
I want to only script like below..
BirchJD
Mon Oct 15, 2018 11:55 am
Rumee,
In GitHub you can view the commits to the project:
https://github.com/BirchJD/PiOBDII/commits/master
Get the code at one of the early commits, I think it was the second commit when I was just pulling back trouble codes.
Jason
Return to “Python”
