ronnih
[solved] Failed to mount NFS Partition at boot
Thu Apr 26, 2018 6:53 pm
my Desktop (RPi3) has problems to mount my NFS Partition from my File-Server(RPi2). It works over one year perfect but now after the installation of a new Router or last update I have this problem. :cry:
After Login in my Desktop(LXDE)and open the LXTerminal and mount the NFS Partition with
sudo mount -a
and all is good and with no problem. But why it is not working at boot?
All my RPi's have the newes Updates from Raspbian Stretch.
Here is the Error Message:
Apr 25 18:58:27 iglu systemd[1]: media-DataNFS.mount: Mount process exited, code=exited status=32
Apr 25 18:58:27 iglu systemd[1]: Failed to mount /media/DataNFS.
Apr 25 18:58:27 iglu systemd[1]: Dependency failed for Remote File Systems.
Apr 25 18:58:27 iglu systemd[1]: remote-fs.target: Job remote-fs.target/start failed with result 'dependency'.
Apr 25 18:58:27 iglu systemd[1]: media-DataNFS.mount: Unit entered failed state.
Apr 25 18:58:27 iglu systemd[1]: home-tux-NFSFreigabe.mount: Mount process exited, code=exited status=32
Apr 25 18:58:27 iglu systemd[1]: Failed to mount /home/tux/NFSFreigabe.
Apr 25 18:58:27 iglu systemd[1]: home-tux-NFSFreigabe.mount: Unit entered failed state.
Edit - after the installation of a new Router
https://techguru.lima-city.de
donbrew
Re: Failed to mount NFS Partition at boot
Thu Apr 26, 2018 10:53 pm
If you are using something like sda1 in the fstab New kernel prefers that you use UUID that you can find with the blkid command.
Like this: UUID=4C4CF5224CF5078A /mnt/pihdd ntfs defaults,auto,umask=000,users,rw 0 0
not this: dev/sda /mnt/pihdd ntfs default ...........etc.
The sda sdb etc can change with no notice or reason, the UUID doesn't.
Just my guess.
ronnih
Fri Apr 27, 2018 9:10 am
Hello donbrew,
thx for you answer :)
Think it is not the problem because it is a Network File System here the blkid command shows only the local partitions. And on my NFS-Server the partions are all right mounted.
In my opinion it is something with the network.
PeterO
Fri Apr 27, 2018 9:13 am
Does the NFS mount work if performed manually ?
PeterO
ronnih
Fri Apr 27, 2018 9:15 am
Yes,
sudo mount -a
after login in my LXDE Desktop mounts my NFS-Patitions with no problems.
PeterO
Fri Apr 27, 2018 9:46 am
Ok, what do you have in /etc/fstab ?
I use lines like this to automount directories from my NFS server as they are required.
192.168.1.21:/MINT-17/opt/RPI /opt/RPI nfs vers=4,rsize=8192,wsize=8192,timeo=14,intr,noauto,x-systemd.automount 0 0
PeterO
ronnih
Fri Apr 27, 2018 11:15 am
My /etc/fstab:
deflu:/media/DataB/Data		/media/DataNFS  nfs4  rw,nosuid 0 0
deflu:/media/DataB/NFSFreigabe	/home/tux/NFSFreigabe  nfs4  rw,nosuid 0 0
Have saved your automount line. It can be also good for me. :)
HawaiianPi
Fri Apr 27, 2018 10:38 pm
You might want to try enabling Wait for Network in raspi-config.
ronnih
Sat Apr 28, 2018 7:42 am
Thx very good HawaiianPi,
now my NFS Partitions are mounted during boot.
The Problem is solved :D
Return to “Raspberry Pi OS”
