Assuming it's a USB device then any guide for using it on Linux should work. If you need more detailed help then you're going to have to find someone with the same hardware, in which case this might not be the right place.Dicecelo wrote: ↑Tue Apr 24, 2018 7:44 pmSo im absolutely new to anything that has to do with raspberry pi's, and what happens is that I got a BioInfoBanks PicoStokcs 100th-mine that I need to make work, if any of you guys could post a link with a tutorial or write the script I would really appreciate that (btw I just googled thistopic but idk if it will work because he is using a different miner viewtopic.php?t=103046).
