tetosan
Problems with Zero Delay USB encoder
Tue Apr 24, 2018 12:02 pm
Hello all!
First of all, thanks to this community that have saved my ass so many times! :D
I'm messing around with an USB encoder Zero Delay as in the image below:
And I have the following problems:
1. I know that joystick comes with a default configuration but I have had to turn around the joystick and I would like to modify X and Y axis.. how can I do it?
2. To enable joystick, I have to plug a button to the MODE socket and when I press it, LED light change between red and green, I have to leave it in green for the Joystick to work. Does anyone know how to leave permanent in green and do not need to have this button plugged on MODE socket?
3. I would like to configure buttons action from file configuration. Does anyone know which file is and when I can find it?
Hope you can help me out.
Best Regards,
mikfoley
Re: Problems with Zero Delay USB encoder
Mon Aug 13, 2018 3:08 pm
Hi, I was curious if you found a solution for this? I have the same issue with mine and would rather not add a button dedicated to the mode switch if I don't have to.
Thanks!
