pi_lover
How to disable screen blanking ?
Tue Apr 24, 2018 8:27 am
The screen goes dark after a period of inactivity ... How to stop this ?
RaTTuS
Re: How to disable screen blanking ?
Tue Apr 24, 2018 8:47 am
edit /boot/cmdline.txt *
and add
consoleblank=0
right after the rootwait
then reboot
if using NOOBS
then
Use the NOOBS recovery system [spam the [SHIFT] key during boot to activate it] and edit that /boot/cmdline.txt
Covfefe
pi_lover
Tue Apr 24, 2018 9:23 am
Yes I am using Noobs.
What exactly should I add to that /boot/config.txt?
B.Goode
Tue Apr 24, 2018 9:33 am
Exactly nothing.
I think there was a minor typing error - maybe due to autocorrect - in the second part of the advice above.
It is cmdline.txt that you need to modify with the Configuration Editor on the NOOBS Recovery Console.
pi_lover
Tue Apr 24, 2018 9:37 am
If I create a script with "xset s off" and run it will it work ?
weeper
Wed Apr 25, 2018 12:21 am
You can install an application:
sudo apt-get install xscreensaver
After installation. Go to Menu => Preferences => Screensaver, then just disable it there :)
klricks
Wed Apr 25, 2018 1:11 am
I believe the edit to cmdline mentioned above is only useful if the system is set to boot to command line only.
For boot to desktop then adding the 3 lines below to autostart works for me.
Edit with nano editor:
nano /home/pi/.config/lxsession/LXDE-pi/autostart
Add these 3 lines at the end:
@xset s noblank
@xset s off
@xset s -dpms
Save and exit CTRL x Y
xscreensaver also works but you have to install 40MB of fluf.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
pi_lover
Wed Apr 25, 2018 10:18 pm
@klricks
Your solution worked. Thanks a lot.
hippy
Mon Jan 14, 2019 1:58 am
@xset s noblank
@xset s off
@xset s -dpms
I could have sworn this also worked for me when I tried it earlier this year, but on a virgin Raspbian Desktop install ( image not NOOBS, no recommended software, updated to today, boot to GUI ), creating that file ( it didn't already exist ) with those contents just leaves me with a black screen after a reboot, albeit that the mouse cursor is there. Delete the file and reboot and everything is fine again.
Any ideas or suggestion on how to debug, find out what's wrong, or make it work ?
klricks
Mon Jan 14, 2019 1:14 pm
Due to changes to mentioned in the blog, Raspbian now uses the global autostart in this location:
/etc/xdg/lxsession/LXDE-pi/autostart
If you prefer to use the one at /home/pi/.config/.......... then it must contain these lines:
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@point-rpi
If autostart exists at /home/pi/.config/.... then the one at /etc/xdg/....... is ignored.
To stop screen blanking you only need these 2 commands:
@xset s off
@xset -dpms
hippy
Mon Jan 14, 2019 1:45 pm
Due to changes to mentioned in the blog, Raspbian now uses the global autostart in this location ...
Ah yes. Many thanks for that. I had completely forgotten about that change :oops:
If disabling screen blanking had been a raspi-config or clickable desktop preferences or appearance option I wouldn't have had to care about what needed altering or where settings were stored.
It would be nice if options like this could be made more easily accessible than having to manually edit configuration files but I'm not going to suggest percussive re-education of any developers.
WhyNine
Thu May 30, 2019 7:25 pm
I have an LCD screen on the Pi which is set as the main display on boot and displays the desktop. I want to use it as a displaybaord/kiosk so I have set up a service which runs a script file containing:
#!/bin/bash
xset -display :0 s off
xset -display :0 s noblank
xset -display :0 -dpms
unclutter -display :0 &
# Normal website that does not need any exceptions
/usr/bin/chromium-browser --enable-gpu-compositing --remote-debugging-port=9222 --incognito --start-maximized --kiosk file:/home/pi/Pi-Plex/index.html
My web page displays correctly as full screen but the screen still blanks after 5-10 minutes. If I SSH to the Pi and type "xset -display:0 -dpms", the screen unblanks again.
What am I doing wrong?
I have also tried putting the xset commands in the /etc/xdg/lxsession/LXDE-pi/autostart file but no joy.
It is very frustrating :?
klricks
Fri May 31, 2019 5:50 am
Did you install xscreensaver? xset commands won't work if xscreensaver is installed.
WhyNine
Fri May 31, 2019 8:00 pm
No, xscreensaver is not installed.
WhyNine
Fri May 31, 2019 8:43 pm
If I type "xset -display :0 -dpms" in a terminal, the screen never goes blank.
Roken
Fri May 31, 2019 10:06 pm
Or, the traditional xorg way. Edit /etc/X11/xorg.conf and in the Monitor section, add
Option	"DPMS" "off"
Headless PI. OMG, someone cut it's head off. Oh, hang on. it didn't have one to start with.
klricks
Sat Jun 01, 2019 1:15 am
Do you have another autostart file anywhere in /home/pi/.config/........
If so the one in /etc/xdg/........ will be ignored.
Note this will show the current settings of the xset commands:
xset q
WhyNine
Sun Jun 02, 2019 4:14 pm
Option	"DPMS" "off"
That seems to have done the trick. Many thanks for that tip. :D
matteoraggi
Sun Jun 09, 2019 5:48 pm
Raspbian stretch changed a lot from november 2018 are you sure that these informations are updated? Which instructions should I use to disable the blank screen with raspbian stretch of may 2019?
Raspberry Pi 3 model B - Raspbian 8 Jessie
WhyNine
Sun Jun 09, 2019 6:17 pm
The "xorg.conf" file is actually in the /usr/share/X11/xorg.conf.d folder. I have a number of files in there and one of them already had a Device section so I added a Screen and Monitor section as well, with the suggested Option. However in the end that didn't fix it (it did after one reboot but not thereafter for some reason).
So my fix was to add a file in /etc/profile.d called screen.sh (the name doesn't matter) with:
It's a bit of a hack but works for me. :D
Return to “Raspbian”
