Hi everyone I'm in a bit of a pickle. I have an issue in regards to a backup image made with win32 disk imager last year.
I had a corrupt card a week ago meaning I had to reformat and reload my os. I was running retropie 4.3 on a pi3. (Not the 3b+)
Last year when I used win32 to 'read' my card to produce a backup for safety, it all went ok and told me it was successful. So I went and stored on my external HDD for when I needed it again.
Ok so after my corruption it came the time when I needed it. I went to use win32 disk imager to write the image to the card and it's says it's successful, but when the card is put into the pi, there is no boot at all, absolutely nothing. Windows will not detect the boot partition either and tells me the card needs formatting before use (even just after writing the image). The things I've tried are using a new fresh image and wrote to the same card Which worked and booted fine (so I can rule out a duff card). I've written my backup image to other cards with the same no boot effect. I've formatted the card using windows and fat32 SD formatter. So what I was wondering, there anyway of checking the integrity of my backup image? And being able to fix it for boot? As it seems to be the image at fault but I'm sure as to why? I'm gutted that I can't get all my games, saves and configs back. I don't know if it helps but the card I used to make my backup is a SanDisk ultra 32gb.
Can somebody help? Thanks in advance guys
