sakaki
How to install and run 32-bit Raspbian apps on 64-bit Gentoo (RPi3 B/B+)
Tue Apr 17, 2018 7:00 pm
if you are running a 'pure' 64-bit Gentoo system on your RPi3 B / B+ (such as my gentoo-on-rpi3-64bit image), you may sometimes find yourself wishing you could just install and run a particular 32-bit package from Raspbian, if it has not yet been added to the Gentoo arm64 tree.
Well, the good news is you can, while still running your 64-bit Gentoo, since mixed-mode userland is permitted on ARMv8! I've just posted a new wiki tutorial, showing how to install a 32-bit Raspbian chroot on your gentoo-on-rpi3-64bit system, then, using this, install 32-bit apps (using apt-get) from Raspbian, and run them alongside 64-bit Gentoo apps on your (64-bit) desktop. The example app I use in the tutorial is Lazarus (but you can obviously install anything you like). Here's a screenshot of 32-bit Raspbian Lazarus running on an 64-bit Gentoo RPi3 B+:
Have fun, sakaki ^-^
ejolson
Re: How to install and run 32-bit Raspbian apps on 64-bit Gentoo (RPi3 B/B+)
Fri May 25, 2018 4:39 am
Does the 32-bit version of Mathematica included free with Raspbian work?
sakaki
Sat May 26, 2018 3:01 pm
Yes, it works:
To get this to run, I followed the instructions cited above, but used the full Raspbian as a "donor" image (and made sure to start Mathematica once within that image booted natively first, to ensure all setup had been completed), and also placed the following (executable) script in /usr/local/bin/uname (inside the chroot filesystem, to allow Mathematica's startup system ID to pass):
#!/bin/bash
# Override reported uname --machine type in chroot, to armv7l
# as some programs like mathematica check this
# Copyright (c) 2018 sakaki <[email protected]>
# License: GPL v3+
# NO WARRANTY
if ((1==${#})) && [[ "-m" == "${1}" || "--machine" == "${1}" ]]; then
	echo "armv7l"
else
	# pass to default handler
	/bin/uname ${@}
fi
hth, sakaki
Gavinmc42
Sun May 27, 2018 2:32 am
Mathematica :o
Wow, pick something small, not :D
Wonder if the command line Wolfram will compile in Aarch64?
Never checked to see if there was source code :oops:
Sakaki, you want to try the camera next?
viewtopic.php?f=29&t=213435&p=1320360#p1320360
I'm dancing on Rainbows.
ejolson
Mon Jun 18, 2018 9:33 pm
Yes, it works:
#!/bin/bash
# License: GPL v3+
# NO WARRANTY
	echo "armv7l"
else
	/bin/uname ${@}
fi
hth, sakaki
Great news! Thank you for testing this and figuring out how to make it work.
Return to “Gentoo”
