paulslocum
Is hdmi_force_hotplug the same as manually turning on HDMI via tvservice?
Tue Apr 17, 2018 2:12 pm
Does hdmi_force_hotplug=1 do anything unique, or is it the effectively same as automatically turning on an HDMI mode using tvservice in rc.local?
Re: Is hdmi_force_hotplug the same as manually turning on HDMI via tvservice?
Tue Apr 17, 2018 2:27 pm
hdmi_force_hotplug forces the GPU to enable the HDMI settings even when there's no HDMI device connected. You'll usually need to include hdmi_group=n & hdmi_mode=nn with some override settings for your HDMI device.
This is a doctor free zone.
paulslocum
Wed Apr 18, 2018 2:59 pm
Best I can tell, tvservice does the same thing. What I'm wondering is if there's any difference between the two technically, like does hdmi_force_hotplug set some bits on the HDMI port to improve compatibility, or is it only forcing the HDMI on (the same as turning on an explicit HDMI mode with tvservice)
Wed Apr 18, 2018 3:35 pm
The config.txt option is automatic at boot time. Most folks won't ever need it, 99.99% of HDMI display devices "just work" with a Raspberry with nothing special needed in /boot/config.txt or with the tvservice command.
paulslocum
Wed Apr 18, 2018 9:00 pm
I hope so, but I find quite a few reports of the issue on the forums, and I didn't have to test many devices to find one that didn't work, so I think the issue may be more a bit more prevalent than that.
