PaulitaPerezB
Problem connecting two BT devices to a Pi3
Tue Apr 17, 2018 12:08 am
I want a HC-06 and a HC-05 BT modules connect simultaneously to the Pi3 using rfcomm.
I normally connect one module with the following command and it works for me.
sudo rfcomm connect hci0 XX:XX:XX:XX:XX:XX
But now I want to connect two modules so I tried this and return an error.
sudo rfcomm connect hci0 XX:XX:XX:XX:XX:XX sudo rfcomm connect hci1 XX:XX:XX:XX:XX:XX
I want to know if there are a way to connect to devices to the Pi3 simultaneously. Because I need to use it to receive data from an Arduino and send orders to another. I do it with a Python script using PySerial.
Douglas6
Re: Problem connecting two BT devices to a Pi3
Tue Apr 17, 2018 6:42 pm
What error are you getting? You could try
sudo rfcomm connect 1 XX:XX:XX:XX:XX:XX
PaulitaPerezB
Tue Apr 17, 2018 7:46 pm
I could fix the problem!! thank you!
I tried this to connect the first module.
and this to connect the second one:
sudo rfcomm connect 2 XX:XX:XX:XX:XX:XX
Douglas6
Tue Apr 17, 2018 7:51 pm
That's interesting. I would have thought it would be '0' and '1'. Those BlueZ rascals. Although if rfcomm can't determine a valid device number, it defaults to hci0, so maybe '1' and '2' ends up being hci1 and hci0?
