minipixel
SPI delay between bytes is different for small and large transfers (spidev)
Mon Apr 16, 2018 4:51 pm
I am investigating the SPI behaviour on Raspberry Pi 3 Model B. I am using spidev. One thing that keeps me awake at night is the following:
  • when performing a transfer of 95 bytes or less, I get a delay between each byte of around 1.5 of the SCLK period:
  • when performing a transfer of 96 bytes of more, there is no delay between bytes:
I have read multiple different forum posts on similar topics but did not get a conclusion on where this setting is comming from and how to control it (if possible at all).
In my application, I am trying to achieve:
1. to control either to make a delay between bytes or not, independent of the transfer size
2. to control the duration of the delay.
I guess No. 2 is more complicated than the No. 1.
Any help is appreciated.
Regards,
minipixel
joan
Re: SPI delay between bytes is different for small and large transfers (spidev)
Mon Apr 16, 2018 5:16 pm
You might need to make a Linux SPI driver change (if the change is not present in the current driver).
I have the following line in the pigpio driver for the main SPI device. I don't remember who discovered this fix, just that it wasn't me.
spiReg[SPI_DLEN] = 2; /* undocumented, stops inter-byte gap */
minipixel
Tue Apr 17, 2018 8:43 am
Wow, this really helped. I have tested the latest pigpio library and I saw that this change is already included there. Thanks!
It's a pitty though that this is hardcoded in the driver. I would rather like to change the behaviour on-the-fly. Does anybody know what is the reset value for this setting?
joan
Tue Apr 17, 2018 10:10 am
You will need to check with the maintainer of the Pi Linux kernel SPI driver (perhaps user msperl, but that may be a faulty memory).
Just to note that pigpio is a userland driver so will still suffer random inter-byte gaps caused by reschedules.
mweetman2
Wed May 09, 2018 8:53 pm
Hi
Did you find a fix for this under spidev? I have the same issue, but see the delay with long buffers when calling writebytes or xfer/xfer2. There is no delay with buffers less than 0x10000 bytes in length, but I see a 1.5 bit time delay between bytes when buffers are 0x10000 byte in length or more.
HiassofT
Thu May 10, 2018 1:09 pm
That's probably the DMA "lite channel" limit. The data has to be split into less than 64k chunks as that's the maximum the DMA controller can do (on the "lite" channels) so a short delay between the chunks is to be expected.
so long,
Hias
calucio24
Fri Apr 19, 2019 10:36 am
Hi guys, I have the same problem. I'm using pi4j and I'm writing 8 bytes with every bit to 1 at 40Khz.
With an oscilloscope, I notice that in my MOSI line, I see 0 level every each byte.
Pi4J is based on wiringPi, so how can I fix it?
