So, when I bought the Raspberry Pi Zero (not W) , I was interested in the premise of USB gadgets. The trouble is, that I wanted to setup something similar to this: https://www.novaspirit.com/2016/10/18/r ... sb-dongle/
So I grabbed the necessary files, installed the latest version of Raspbian, yet for some unforseen reason it would not work. I knew I edited the config.txt and the cmdline.txt, plus added the necessary addons. I also checked that I plugged in the USB lead in the port marked USB, not the PWR IN port. I even tried checking if my Raspberry Pi's USB is fried by plugging it in without an SD Card. It showed up on both Windows and Linux as the Broadcom device it's supposed to show up as. Yet even when I try using the latest Raspbian, it still does not show up, not even as the incorrect device. So, what I was wondering is if someone whose config works would please be able to prepare an image with everything set up for an RNDIS adapter (g_ether) which I can download by using Win32DiskImager. Thanks in advance.
