Hello!
I'm having problems with a TP-Link TL-WN823N WiFi adapter.
Plugging it in, nothing happens.
I've read other posts here and followed their advice, but it does not work.
dmesg | grep usb shows it as a 802.11n NIC from Reaktek, but clicking on the "Wired & Wireless Network Settings' icon shows "No wireless interfaces found".
I've used Ethernet to run sudo apt-get update then sudo apt-get dist-upgrade and rebooted, but nothing.
Using MrEngman's install-wifi does not work, giving errors.
The last few lines of output are:
Installing driver module 8192eu.ko.
/usr/bin/install: line 1: --2016-02-07: command not found
/usr/bin/install: line 2: syntax error near unexpected token `('
/usr/bin/install: line 2: `Resolving www.fars-robotics.net (www.fars-robotics.net)... failed: Name or service not known.'
Loading and running the 8192eu driver, 8192eu.ko.
modprobe: FATAL: Module 8192eu not found.
Ethernet is impractical is only for a temporary solution
Any ideas?.
