kharris
Issue installing Linux Headers
Thu Apr 12, 2018 5:38 pm
I have a Raspberry Pi 3, running Stretch and I am trying to setup a USB driver for a motor controller. I'm trying to follow the instructions for setting up the driver, but I am running into the below issues when I try to execute the following command (which is step 1 of the instructions for setting up the driver):
sudo apt-get install linux-headers-$(uname -r)
which outputs:
Reading package lists... Done
Building dependency tree
E: Unable to locate package linux-headers-4.9.80-v7
E: Couldn't find any package by glob 'linux-headers-4.9.80-v7'
E: Couldn't find any package by regex 'linux-headers-4.9.80-v7'
In addition, when I execute:
uname -mrs
I get:
Linux 4.9.80-v7+ armv7l
Finally, I also tried checking which linux-headers are available with the following:
apt-cache search linux-headers
aufs-dkms - DKMS files to build and install aufs
linux-headers-3.10-3-all - All header files for Linux 3.10 (meta-package)
linux-headers-3.10-3-all-armhf - All header files for Linux 3.10 (meta-package)
linux-headers-3.10-3-common - Common header files for Linux 3.10-3
linux-headers-3.10-3-rpi - Header files for Linux 3.10-3-rpi
linux-headers-3.16.0-4-all - All header files for Linux 3.16 (meta-package)
linux-headers-3.16.0-4-all-armhf - All header files for Linux 3.16 (meta-package)
linux-headers-3.16.0-4-common - Common header files for Linux 3.16.0-4
linux-headers-3.16.0-4-rpi - Header files for Linux 3.16.0-4-rpi
linux-headers-3.18.0-trunk-all - All header files for Linux 3.18 (meta-package)
linux-headers-3.18.0-trunk-all-armhf - All header files for Linux 3.18 (meta-package)
linux-headers-3.18.0-trunk-common - Common header files for Linux 3.18.0-trunk
linux-headers-3.18.0-trunk-rpi - Header files for Linux 3.18.0-trunk-rpi
linux-headers-3.18.0-trunk-rpi2 - Header files for Linux 3.18.0-trunk-rpi2
linux-headers-3.6-trunk-all - All header files for Linux 3.6 (meta-package)
linux-headers-3.6-trunk-all-armhf - All header files for Linux 3.6 (meta-package)
linux-headers-3.6-trunk-common - Common header files for Linux 3.6-trunk
linux-headers-3.6-trunk-rpi - Header files for Linux 3.6-trunk-rpi
linux-headers-4.4.0-1-all - All header files for Linux 4.4 (meta-package)
linux-headers-4.4.0-1-all-armhf - All header files for Linux 4.4 (meta-package)
linux-headers-4.4.0-1-common - Common header files for Linux 4.4.0-1
linux-headers-4.4.0-1-rpi - Header files for Linux 4.4.0-1-rpi
linux-headers-4.4.0-1-rpi2 - Header files for Linux 4.4.0-1-rpi2
linux-headers-4.9.0-6-all - All header files for Linux 4.9 (meta-package)
linux-headers-4.9.0-6-all-armhf - All header files for Linux 4.9 (meta-package)
linux-headers-4.9.0-6-common - Common header files for Linux 4.9.0-6
linux-headers-4.9.0-6-common-rt - Common header files for Linux 4.9.0-6-rt
linux-headers-4.9.0-6-rpi - Header files for Linux 4.9.0-6-rpi
linux-headers-4.9.0-6-rpi2 - Header files for Linux 4.9.0-6-rpi2
linux-headers-rpi - Header files for Linux rpi configuration (meta-package)
linux-headers-rpi-rpfv - This metapackage will pull in the headers for the raspbian kernel for the
linux-headers-rpi2 - Header files for Linux rpi2 configuration (meta-package)
linux-headers-rpi2-rpfv - This metapackage will pull in the headers for the raspbian kernel for the
linux-libc-dev-alpha-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-arm64-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-armel-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-armhf-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-hppa-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-m68k-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-mips-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-mips64-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-mips64el-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-mipsel-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-powerpc-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-powerpcspe-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-ppc64-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-ppc64el-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-s390x-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-sh4-cross - Linux Kernel Headers for development (for cross-compiling)
linux-libc-dev-sparc64-cross - Linux Kernel Headers for development (for cross-compiling)
raspberrypi-kernel-headers - Header files for the Raspberry Pi Linux kernel
If anyone is able to offer insight into what I'm doing wrong or what the issue is, that would be AMAZING! Newish to RaspberryPi, so still learning.
ShiftPlusOne
Re: Issue installing Linux Headers
Fri Apr 13, 2018 2:53 pm
raspberrypi-kernel-headers is the package to match raspberry-kernel
B.Goode
Fri Apr 13, 2018 3:20 pm
Try
sudo apt update
again, followed by
sudo apt install <<your requirements here>>
Pokerfjes
Sat Apr 14, 2018 6:32 pm
I think we have the same problem, but if we don't I'll butt out ;). I just downloaded latest image, apt-get updated and upgraded, then fetched the raspberrypi-kernel-headers package.
root@raspberrypi:~# uname -a
Linux raspberrypi 4.9.80-v7+ #1098 SMP Fri Mar 9 19:11:42 GMT 2018 armv7l GNU/Linux
root@raspberrypi:~# ls /lib/modules/
4.14.30+ 4.14.30-v7+
This is the location of the headers I think. Why do they contain headers for an old kernel.
B.Goode
Sat Apr 14, 2018 7:38 pm
It could easily be irrelevant, but just on the chance that it is related, could you indulge my curiosity and try the trivial potential fix that I posted?
scruss
Sat Apr 14, 2018 7:44 pm
uname gives the version of the running kernel. If you haven't rebooted since updating, you'll still be running the old kernel.
The package the OP wants is raspberrypi-kernel-headers: no version required.
Pronouns: he/him
Return to “Linux Kernel”
