JRos
Compute module soldered to the main PCB
Thu Apr 12, 2018 6:10 am
Has anyone made experience with soldering the Compute Module directly to a PCB?
I know that it is intended to fit the device in a DDR2 SODIMM socket. But if a removal of the Compute Module is not planned, the socked could be saved.
So, are there arguments against soldering?
Re: Compute module soldered to the main PCB
Thu Apr 12, 2018 6:15 am
Put it in a SODIMM socket then hot-glue it in there. The SODIMM connector is double sided so you can't just solder it to a board.
mikerr
Thu Apr 12, 2018 9:20 am
The essential pins are duplicated on either side of the connector (VBAT, 1V8, 3V3 etc)
- so it is possible to use only one side, depending on what other features you want to use.
https://www.raspberrypi.org/documentati ... T-V1_0.pdf Page 11
Small designs are available with the socket though:
https://www.wdc.com/products/wdlabs/med ... ry-pi.html
https://www.wdc.com/products/wdlabs/wd- ... odule.html
https://store.gumstix.com/development-b ... flash.html
aBUGSworstnightmare
Thu Apr 12, 2018 2:33 pm
How do you want to save money? Socket is placed by pick & place machine, soldered in reflow oven.
How do you want to solder the Compute module to your board as reflowing it might not be possible...
And... How many thousands of units to be build?
Return to “Compute Module”
