dkwsloth1
Using a relay, with USB and not GPIO
Thu Apr 05, 2018 11:03 pm
Hello all,
I am a 100% newbie.
I am looking to use a simple control to trigger an action. I have some code used for GPIO, however I would like to connect to my relay using the USB port instead of the pins. can someone please help to modify the code to talk to the USB port, instead of using the pins.
Is there an easy way tell the Pi, to do the GPIO operation using the USB?
THANKS,
here is the current code:
import web, requests
import RPi.GPIO as GPIO
import time
urls = ('/advance/(.*)/(.*)', 'advance')
app = web.application(urls, globals())
class advance:
def GET(self, digi_cam_ip, loops):
for loop in range(0, int(loops)):
# specify how the pins are referred to
GPIO.setmode(GPIO.BOARD)
# pin the relay is connected to on the Raspberry Pi
pin = 2
# activate the relay for 0.25 seconds, then release
GPIO.setup(pin, GPIO.OUT)
GPIO.output(pin, GPIO.LOW)
time.sleep(0.25)
GPIO.output(pin, GPIO.HIGH)
GPIO.cleanup()
# wait for the projector to advance the slide
time.sleep(0.5)
# take the picture by calling DigiCam's webservice
requests.post("http://" + digi_cam_ip + ":5513/?CMD=Capture")
# wait for the image to transfer from the camera to the computer
time.sleep(2)
return "Finished"
if _name_ == "__main__":
app.run()
klricks
Re: Using a relay, with USB and not GPIO
Fri Apr 06, 2018 2:11 am
Hello all,
I am a 100% newbie.
THANKS,
You will need to get documentation and programming examples from the seller / manufacture of your addon USB controlled relay board or USB IO board.
Post a link to your board.
When you post code please use the code tags button [</>] so that your code looks like this:
 import time
 class advance:
 pin = 2
 time.sleep(0.25)
 GPIO.cleanup()
 time.sleep(0.5)
 time.sleep(2)
 return "Finished"
 app.run()
