hoenens
Screen upside down
Thu Apr 05, 2018 4:54 pm
Ok, in Raspbian i know the LCD_ rotate line in the config to fix it, but i am using berryboot now, can i change this here aswell.
Also when i boot into retropi, screen is now also upside down. How to fix this so the screen is always the right way?
hoenens
Re: Screen upside down
Thu Apr 05, 2018 5:24 pm
Within raspbian now whan i wanna config the boot/config.txt when i open it in the terminal it's empty....
Thu Apr 05, 2018 10:03 pm
sudo nano /boot/config.txt
Make sure you have that first /
Thu Apr 05, 2018 10:09 pm
/boot/config.txt can be empty. In most cases the RPi will boot perfectly and the default configuration will "just work".
For lots of settings, the easiest way to set options in /boot/config.txt (and /boot/cmdline.txt) is with sudo raspi-config. Except in this case.
You can write a single line option into /boot/config.txt with
sudo sh -c 'echo "lcd_rotate=2" >> /boot/config.txt' if you don't like sudo nano.
