rogermiranda1000
Connection to dhcpcd lost
Sat Mar 31, 2018 9:32 pm
I was making IPv4 static modifying /etc/network/interfaces, this is my code:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
	address 192.168.1.10
	netmask 255.255.255.0
	network 192.168.0.1
	gateway 192.168.1.1
	dns-nameservers 8.8.8.8 8.8.4.4
auto wlan0
iface wlan0 inet static
	wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
	address 192.168.1.11
	network 192.168.0.1
	gateway 192.168.1.1
The IP works fine, but I Raspberry says "No wireless interfaces found" (the Raspberry connects to Wi-Fi if it's putted in /etc/wpa_supplicant/wpa_supplicant.conf).
SurferTim
Re: Connection to dhcpcd lost
Sun Apr 01, 2018 12:08 pm
If you are using Stretch, which you should be, your static settings should be set in /etc/dhcpcd.conf. Your entry in /etc/network/interfaces will cause the dhcpcd service to fail.
My advice applies to RaspiOS only. Please mention if you use another OS.
rogermiranda1000
Thu Jun 14, 2018 10:20 am
It works, thanks!
thanospi
Thu Nov 28, 2019 9:15 pm
For me the best solution was the next configuration:
auto lo
auto eth0
address 192.168.0.50
network 192.168.0.0
broadcast 192.168.0.255
gateway 192.168.0.1
auto wlan0
iface wlan0 inet dhcp
I have the ip and I can access to internet
josh1
Tue Jun 16, 2020 10:28 am
It works, thanks!
Where did you put the configuration?
/etc/dhcpcd.conf or /etc/network/interfaces?
I uninstalled my Pihole and I’m disconnected from the internet.
