count_wakula
SAMBA refuses to work
Sat Mar 31, 2018 7:53 pm
Good afternoon,
I am trying to setup a home NAS system with the raspberry pi.
I got a 3B+ starter kit and a 256 GB USB drive for storage.
Installed the latest version of Raspbian Lite. SSH works fine and connectivity works.
I installed the exfat fuse driver and set the "mount point" to /mnt/PIHDD/.
Below is the output of the "sudo -l /mnt/" command:
drwxrwxrwx 1 root root 131072 Jan 1 1970 PIHDD
From what I understand this means that "PIHDD" has read/write access enabled.
I also added an entry to the fstab file to enable automounting for "PIHDD."
Next I installed samba via the following command:
sudo apt-get install samba samba-common-bin
After that I added the following data to the "/etc/samba/smb.conf" file (at the end of the file):
[share]
comment = PIHDD
path = /mnt/PIHDD/
browseable = yes
writeable = yes
only guest = no
create mask = 0777
directory mask = 0777
public = yes
guest ok = yes
I didn't make any other changes to the smb.conf file.
After that I added a samba user via the following command:
sudo smbpasswd -a pi
And restarted samba: sudo /etc/init.d/samba restart. Restart seemed to have worked.
However, when I run the "sudo smbstatus --shares" command I get nothing. Windows 10 also doesn't see the share.
What am I doing wrong and how to I troubleshoot this issue?
I don't believe it's an issue with my router setup (I made the router assigns the pi with a fixed IP).
I have a feeling that it will impossible to get samba running, it doesn't really strike me as a solution designed for "outcome enablement". Are there any alternatives to messing with samba? I tried installing OMV on raspbian lite, I was able to access the webUI, but the solution was extremely unstable and for some reason it kills SSH access (wasn't able to fix it and I am not wasting any more time troubleshooting this issue). The raspberry pi install image for OMV won't load at all.
Thanks.
hortimech
Re: SAMBA refuses to work
Sun Apr 01, 2018 7:34 am
It should work, but is Samba actually starting ?
Try these two commands:
ps ax |grep -v 'grep' | grep 'smbd'
ps ax |grep -v 'grep' | grep 'nmbd'
It should produce lines like these:
7366 ? Ss 0:00 /usr/sbin/smbd -D
7304 ? Ss 0:05 /usr/sbin/nmbd -D
If you don't get any output, neither the 'smbd' or 'nmbd' deamons is running, so try starting them separately:
sudo /etc/init.d/smbd start
sudo /etc/init.d/nmbd start
Then check if they are now running using the two commands you used previously.
Sun Apr 01, 2018 9:08 am
Run sudo testparm to syntax check your smb.conf file.
count_wakula
Sun Apr 01, 2018 4:28 pm
This is what I get running the commands from above:
  518 ?        Ss     0:00 /usr/sbin/smbd
  519 ?        S      0:00 /usr/sbin/smbd
  520 ?        S      0:00 /usr/sbin/smbd
  523 ?        S      0:00 /usr/sbin/smbd
516 ?        Ss     0:00 /usr/sbin/nmbd
I am assuming this means that the smbd and and nmbd services are indeed running.
I tried to run the start commands again
but when I run "sudo smbstatus --shares" it still doesn't show any shares.
Service      pid     Machine       Connected at                     Encryption   Signing
This is what I get when running the sudo testparm command:
Load smb config files from /etc/samba/smb.conf
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
WARNING: The "syslog" option is deprecated
Processing section "[homes]"
Processing section "[printers]"
Processing section "[print$]"
Processing section "[share]"
Loaded services file OK.
Server role: ROLE_STANDALONE
I couldn't find the "rlimit_max" keyword when doing a F6 search via nano. At any rate, it's not that windows can't see the share, but from what I understand the lack of results for "sudo smbstatus --shares" means that I can't even "see" the share locally?
Do I need to install a samba client on the Pi? Some of the tutorials mentions that you need the samba client too...
Sun Apr 01, 2018 4:30 pm
So your config is OK, your problem lies elsewhere.
count_wakula
Sun Apr 01, 2018 4:32 pm
How can I figure out what's wrong? I am not an expert in Linux so I am not even sure where to start or how to get more information.
Are there any other diagnostic commands that I can run to try troubleshoot this issue?
Do I need to change the permissions of the /mnt/PIHDD to allow samba to have access to that folder? From what I understand, right now only root has read/write access to /mnt/PIHDD/, is this normal?
hortimech
Sun Apr 01, 2018 7:24 pm
It looks like everything is working, but you seem to be misunderstanding what 'smbstatus --shares' is for. It doesn't show the shares, it shows who is connected to the share or as Samba calls it the 'Service'.
To see the share, you need to install 'smbclient':
sudo apt-get install smbclient
Then run 'smbclient -L <hostname>
Replace <hostname> with the short hostname of your rpi
You will be asked for a password, just press enter.
It should display info about your Samba server
To connect to share you need to use something like this:
smbclient \\\\<hostname>\\<share> yourpassword
You can find more info about smbclient by running 'man smbclient' on the rpi
Rowland
